Car stumbles and shuts off when warm...
Old Dec 3, 2006 | 03:08 PM
WILLDOGS's Avatar
I shave my change purse
Annoying problem!
When I first start the car in the morning, or any other time the engine is cold,, it starts with no issues.
If I attempt to start the car after the engine is already hot it gives me a crap load of trouble. It will turn over just fine, but when it starts, it sputters and most times just shuts off. The only way I can keep the engine running is to hold down the gas pedal slightly raising the RPM's until the shuttering and stumbling subsides and evens out which usually takes 30secs to a minute.
What would cause this? I already replaced the air filter, ran fuel cleaner, changed plugs and still no dice. I am guessing it is a sensor but not sure which one. I am not getting any CEL's regarding a sensor. The only time I get a CEL is when it reports cylinder misfires due to the engine stumbling.
Any ideas? Could it be the IAC sensor? if so, where is it located and how easy is it to replace myself? Tried searching "IAC" but hard to get results due to only being three letters.
I hope I make sense, i've been up for 28 hrs little out of it...
Old Dec 3, 2006 | 03:43 PM
artbran's Avatar
666 Speed
Did you replace your fuel filter?
Old Dec 3, 2006 | 05:08 PM
GreenMonster's Avatar
Inconsistant idle and stalling is sometimes traced to a dirty IACV...
Search for IACV or idle control valve... Also IAC* can be used to get around the 3 character limitation on the search engine...
https://acurazine.com/forums/showthr...+control+valve
https://acurazine.com/forums/ramblings-12/goddam-its-hot-184758/
Old Dec 3, 2006 | 05:14 PM
jproy's Avatar
MP90 uninstalled
sounds like Idle air control valve IACV mine is starting to let go. I will replace or clean it soon.
Old Dec 3, 2006 | 07:17 PM
fuzzy02CLS's Avatar
Sounds like IAC to me as well. It may be bad.
Fuel filter is not serviceable on the CL. It's in the tank attached to the fuel pump.
Old Dec 4, 2006 | 08:49 AM
WILLDOGS's Avatar
Thanks for the assist guys, I am going to pull it out and try cleaning it first. So should I just buy carb cleaner and spray a shitload of it inside the holes and let it dry? Any procedure on cleaning the valve? I dont want to screw it up with too much spray. Is this even possible? I dont want to ruin the electronic components on the valve.
I see people have cleaned it successfully, but cant find any DYI instructions on it. I will keep searching in the meantime.
Old Dec 4, 2006 | 08:55 AM
I don't think anyone had written up a DYI yet... you might also want to search over on the TL forum too tho... Maybe someone over there has written one up.
Old Dec 4, 2006 | 09:22 AM
fuzzy02CLS's Avatar
Try not to get any in the electrical connection. Other then that just be easy with the carb cleaner. Some cotton swab helps as well.
Old Dec 4, 2006 | 09:37 AM
WILLDOGS's Avatar
ok thanks, will let you know how I make out. Just makes me crazy that the car only stalls and stumbles when the car is hot/wormed up. When the car is cold it runs beautifully.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
jordanboi
Sep 5, 2015 01:33 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
