Car is running lean?
Old Sep 26, 2007 | 02:51 PM
BlackV62K2's Avatar
From a stop or driving around low city speeds, my car is running lean. Basically when I tip into the throttle. When I step on the throttle, the AFR would dip into the 16's (16.0-16.5) and then climb back to 14.0-15.0. If I had to guess, it'll take roughly a second to get back to 14's. When I'm cruising, the AFR is never steady at 14.7. It'll always be moving back and forth between 14.0-15.2 AFR.
My current FP is at 42psi is which higher than it needs to be. Under the boost or near boost the car is pig rich. Tipping into boost (not even 0 VAC on the gauge), it'll already be high 11's-12.0 and in boost, it's in the 10's. Now if I turn the FP down, the car would run leaner in the area I described above but boost AFR would be wayyy better. Any ideas what's wrong with my car?
Old Sep 27, 2007 | 07:22 PM
BlackV62K2's Avatar
Bump
Old Sep 28, 2007 | 01:17 AM
VinceBlkCLS's Avatar
Im still a newb at this but maybe you might have to rich it up and if you have E manage maybe it would help if you reset the ecu bc the car will not notice it is getting more gas thats my 2 cents.
Old Sep 28, 2007 | 08:55 PM
rtatsutani's Avatar
Never had a clean run
I'm not sure about boosted cars but I know our cars do run really lean at low load.
Old Oct 1, 2007 | 04:16 PM
BlackV62K2's Avatar
How lean is really lean for low end on the J32? Is it like I described above. If anyone with a wideband can chime in, that'll be great. Is your AFR like how I described mine?
Old Oct 3, 2007 | 06:59 PM
BlackV62K2's Avatar
Bump
Old Oct 3, 2007 | 07:06 PM
New Image's Avatar
B A N N E D
i believe it runs lean for emission purposes.
my car is the exact same way. super rich at wot. 10s
14.5 -15.9 at cruising speeds and idle
Old Oct 4, 2007 | 01:12 AM
NiteQwill's Avatar
Adventurist.
My car does exactly the same. Seems pretty normal for the CL
Old Oct 4, 2007 | 04:30 PM
BlackV62K2's Avatar
So you guys are tipping into the 16.0+ AFR when you step on the throttle @ low speeds?
Old Oct 4, 2007 | 04:34 PM
New Image's Avatar
B A N N E D
for a short burst yea, but not extended
Old Oct 4, 2007 | 06:20 PM
BlackV62K2's Avatar
Yeah, that's what I'm seeing. Hmm strange, it never did this when I had my J30 + 440cc injectors and 1:1 FPR. It was always 14.7 and never dipped into the 16.0s when I step on the throttle. Right now I'm back to near stock Comptech SC fuel configuration (CT FPR w/ lower FP calibration disc, stock CL-S injectors and Emanage) with 38psi FP @ idle. Emanage is all zero'd except for the voltage map which acts like the ESM. ESM is removed. If this is normal, then I'll not worry about it.
Old Oct 4, 2007 | 06:50 PM
New Image's Avatar
B A N N E D
i think so. im ordering my hpb and emanage ultimate. time to make some serious power
Feb 25, 2020 09:57 AM
Fabian43
Jul 13, 2016 09:07 PM
Phambam12
Sep 6, 2015 06:57 PM
jfman55
Sep 5, 2015 02:55 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
