car problems. pissed off. advice?
Old Jul 1, 2004 | 11:45 AM
BEETROOT's Avatar
Yeehaw
took my car (01 cl-s) to the dealer this morning. this is what I found out.
passenger window won't go down. dealer said something in either my stereo or my alarm screwed it up and they won't touch it.
vibration at highway speeds. said my toe is all screwed up and I need a camber kit. I just got it dropped a month ago and aligned right away. they told me it was within spec...but the dealer said my front tires are at 2mm and rears are 7mm...and the inside of the fronts are completely bald. fuck. its a comptech drop w/ tokico hp. I didn't think it would be this friggen low.
vibration/shake from braking. front rotors are warped. dealer said $280 + tax to replace rotors and pads... wtf.
I'm thinking about going back to stock ride height. I'm so pissed. I just wanted a small drop...my car looks like a fucking lowrider and now I have to buy and install camber kit, and new tires? F that.
I should go trade this pos in for an 04 tl.
Old Jul 1, 2004 | 11:55 AM
ferizzo's Avatar
still a Masshole
Tell them that they should replace the rotors! How many miles on the car? Have you ever had the rotors warp before? I've had my rotors warp twice already (only 33k miles) and both times they have been resurfaced. They even gave me new pads the last time. Show them the TSB on the rotors.
I don't know about the electrical components of the car so someone else will have to chime in. Is it the motor though? Tell them if its the stereo/alarm then why aren't both windows screwed up! How long have you had the stereo/alarm? Why didn't this happen sooner? If the problem was electrical then wouldn't the problem have occurred sooner?
who did the install on the springs? Are the tokico shocks adjustable? if so what setting are they on (highest, lowest)? I think in this case you might be on your own. Don't blame the 01 CLS as this could have happened on any car if the stuff you mention wasn't installed properly. Unfortunately this is the price you pay sometimes when modding a car.
Old Jul 1, 2004 | 11:56 AM
Amoeba's Avatar
Best D-Line in the NFL
From: Gainesville, Fl for college, Palm Beach Gardens, Fl at Home
Damn your TOE is all messed up? I got H&R sports-lower drop, and when I got it aligned they put the toe and caster back to specs along with the front camber, the rear camber was between .14-.44 degrees off, and i have been monitoring it, no inner tread problems on those back tires. Although before and still when Im lowered, the cars steering wheel does vibrate midly on the highway
Old Jul 1, 2004 | 11:57 AM
Rod's Avatar
Rod
Some dealers will make up any BS excuse just to not have to perform any work under warranty. Try another dealer or trying callng the regional manager or Acura Care or whatever it's called. If you're under warranty they should take care of all your problems, well maybe except the alignment, unless you got it done there b/c then it should be warrantied.
Old Jul 1, 2004 | 12:11 PM
BEETROOT's Avatar
Yeehaw
they said the brakes aren't covered by the tsb. I called another dealer...they said it depends on the wear of the brake pads and they would take a look. I'm going to bring it in there instead.
I'm going to play around with fuses and electrical tonight and see if I can fix the window. they said its not the motor or the regulator so its probably a fuse or something simple.
tokico's are not adjustable. I couldn't believe how low it went when I got them...its not what I wanted at all. i just wanted comptech drop...a little lower without being noticeable...an inch or whatever. its blatantly obvious now that my car is lowered. it went down so far that my front tire is about level with the wheel well.
Old Jul 1, 2004 | 12:12 PM
Amoeba's Avatar
Let me see those pics again of your drop please
Old Jul 1, 2004 | 12:13 PM
Bluto's Avatar
Find beauty in dissonance
Where did you get the comptech springs from? new? used?
I've never heard someone complain Comptech was too low.
Old Jul 1, 2004 | 12:16 PM
ferizzo's Avatar
still a Masshole
They are right that the brake pads are not part of the TSB but tell them that if the rotors are warped and the brakes are worn prematurely because of this then they should be responsible. to me its as simple as 1+1=2. Like Rod said, they will say anything to get out of shit!
Old Jul 1, 2004 | 12:19 PM
BEETROOT's Avatar
Yeehaw
http://img.villagephotos.com/p/2004-5/721319/ccar4.jpg
http://img.villagephotos.com/p/2004-5/721319/car.jpg
http://img.villagephotos.com/p/2004-5/721319/car3.jpg
http://img.villagephotos.com/p/2004-5/721319/car2.jpg
Old Jul 1, 2004 | 12:21 PM
BEETROOT's Avatar
Yeehaw
brake pads are at 5mm...they need to be 7mm+ to qualify for the tsb. they aren't prematurely worn...warping started happening two weeks ago.
I'm screwed with the brakes.
I'm just pissed that I need a camber kit with comptech and tokico drop.
Red-CL's Avatar
Doin' da crack shuffle
That sucks.
I don't understand why your having this many problems with a Comptech drop. I remember you showed us that your drop seemed low but mine is the same way. I haven't had any issues with that.
Old Jul 1, 2004 | 12:25 PM
Red-CL's Avatar
That's about the price of a front set of Rotora rotors and stock pads.
Get the hint.
Old Jul 1, 2004 | 12:26 PM
Amoeba's Avatar
I dont know that doesnt look like a comptech drop to me, my h&r sports give barely MORE wheel gap then the comptech drop you have
Old Jul 1, 2004 | 12:33 PM
Rod's Avatar
Rod
Do the tokico's have multiple perch settings?
Old Jul 1, 2004 | 12:35 PM
evilone's Avatar
COME AT ME BRO!
just get a camber kit and hace your rotors milled and get an alarm specliist to take a look at the prob with the window. at my acura dealr once i lowered the car they wont touch it unless its a big rpoblem like trans or something like that. the even refuse to give me an alinement atfer i droped it.
Old Jul 1, 2004 | 12:38 PM
BEETROOT's Avatar
Yeehaw
Get the hint.
yeah I know but I don't have a place to do it, tools, or time. plus I really don't give a shit about brakes. stock brakes work fine for me. whatever.
going to order camber kit from c-c-c.net right now...
Old Jul 1, 2004 | 12:40 PM
fuzzy02CLS's Avatar
Your CT drop does look a bit low. Could just be the tires. Are they stock size tires? I have the same setup & my 235-45-17 on stock rims looked about the same.
Toe & camber have nothing to do with each other. They are different settings. So the dealer telling you the toe is out & you need a camber kit to correct it does not make any sense. I am at the limit for camber with my setup & don't need a kit. My toe was off also & it was set back to specs.
I'd take it to a a tire shop or another dealer to get it checked correctly.
The brakes are a hit & miss dealer issue. I have the same problem. Dealers won't touch them cause I'm lowered & have different rims. Just deal with it. If the pads are fine, have Midus or some shop just cut the rotors for like $65.
The window...How sure are they it's not the window motor. Did they test it to see? What have you done to the car? Alarm? remote power windows?
Edit- I have the same setup as you CT drop & the Tockio shocks
BEETROOT's Avatar
Yeehaw
its a comptech drop, I guess the tokicos just made it go a lot lower. most people with ct drop have stock struts.
I don't think there are multiple perch settings.
and yeah evilone...I'll take it back to the alarm place today and make them fix it.
Old Jul 1, 2004 | 12:57 PM
BEETROOT's Avatar
Yeehaw
yes, stock tire sizes.
a camber kit won't fix the toe? I thought it did...shit. Well I just got it aligned a month ago...I'm taking the dealers alignment specs and the specs from the other shop back to the shop to see what they say.
Old Jul 1, 2004 | 01:04 PM
Pure Adrenaline's Avatar
Dragging knees in
Lower springs + aftermarket struts = lower stance compared to lowering springs w/ stock struts.
I don't know why the dealership says toe is out of spec but you need a camber kit.
Old Jul 1, 2004 | 01:10 PM
Dragging knees in
Camber --
Imagine looking at your tires from the front or the rear of the car. Camber is the degree at which the top of the tire sits relative to the ground. If it's sitting toward the inside of the car, it's negative camber. If toward the outside, it's positive camber.
Negative camber helps with cornering because while turning, the sidewalls have a tendency to flex, and you only get traction on the outer edge of the tread if you have zero camber. However, with a slight negative camber, you will get a bigger contact patch on the tread during a turn.
Toe --
Imagine looking at your car from the top. It's the degree at which the front of the tire (like, toward the front of the car) sits. Negative camber helps with cornering a bit, as well, and it'll give that solid feel in a straightline, especially when cruising on the highway. But 99.9% of the times, you don't need any toe. It's the fastest way to eat up the tires next to burning out.
Old Jul 1, 2004 | 01:11 PM
fuzzy02CLS's Avatar
Stock tires will make it look like more of a drop. If you got some 45 or 40 profile tires under there it won't look like that much of a drop. Remeber the stock tires are 50 series.
Old Jul 1, 2004 | 01:17 PM
Dragging knees in
Well, you can't just throw on 40/45 series tires on it, though, if you want to keep an accurate reading on the speedometer.
Old Jul 1, 2004 | 01:19 PM
fuzzy02CLS's Avatar
Right I mean 235-45-17 or 235-40-18, 225-45-17
Old Jul 1, 2004 | 06:04 PM
BEETROOT's Avatar
Yeehaw
so if the inside of my front tires is now bald...that is a problem from camber correct?
which would require a camber kit....?
Old Jul 1, 2004 | 06:10 PM
NiteQwill's Avatar
Adventurist.
For your window, sounds like your window regulator is messed. The motor may have taken a dump. Your dealer making an excuse saying your stereo or alarm caused it is I would enforce the law on their ass.
Camber = Degree your tire tilts away/to from car
Toe = Degree your tire faces towards center of car
Caster = Degree your tire is facing forward or rear
95% or tire problems involve camber
Old Jul 1, 2004 | 07:25 PM
Rod's Avatar
Rod
I think both incorrect camber and toe could lead to this. I remember Jens stating that what was usually off the most when dropping the CL was the toe which is why he recommended getting an alignment as soon as possible, as opposed to waiting for the spring to settle. And you say that the dealer said what is off is your toe so this should be able to be fixed without a camber kit. That sounds like some real asshole you were speaking too that said you needed a camber kit. You may, but his reasoning makes no sense.
Old Jul 1, 2004 | 09:28 PM
nalleyhoncl's Avatar
2003 cls
yes negative camber and excessive pos. toe will definitely wear your tires prematurely. you will no doubt need a camber kit (you shouldn't have any caster problems), it consists of adjustable front upper balljoints and adjustable rear lower control arms.
Old Jul 2, 2004 | 12:54 AM
BEETROOT's Avatar
Yeehaw
the guy told me that they took the door apart and tested the motor. he said the motor was fine. he said AFTER they checked the motor, they went to check the fuses, saw my stereo wiring, and stopped looking.
I just realized that this is the most blatant I have ever bought. Why would they take apart the whole door and test the motor, BEFORE they popped open the fusebox and checked the fuse? complete and total BULLSHIT.
Old Jul 2, 2004 | 02:47 AM
EricL's Avatar
Fish story from a bunch of fish heads...
Old Jul 2, 2004 | 03:00 AM
EricL's Avatar
The 88-93 Maximas and mid 90 Altimas had the problem of first-year spring sag. I'm mentioning this as I had a ’92 Maxima, my wife still has a 95 Altima,, and there were about four others that were owned by friends and neighbors.
All of the above mentioned Nissans -- that didn't get alignments during the first year -- had serious front-end tire wear (toe related). The inside of the front tires were severely worn. My wife was spared by having an alignment when the car hit 6-months. The neighbor next door had the identical car with a stick and blew off the alignment. She had to purchase new tires way before she should have; there were in bad shape for so few miles.
So, spring sag can cause toe problems (spring sag == lowering). I've seen it. I remember Jens mentioning the toe issue and it should and can be corrected without a camber kit. (obvious comment).
If the camber can be moved close to the factory spec, you might be able to get away without a camber kit if you do a fair amount of driving in the hills; it really depends on the tires and your mix of twisty to straight-line driving. IOW, if you are going to really be doing some heavy work up in the hills, you might be able to get the negative camber to help handling and keep the wear in check. (Do consider all possibilities.)
The toe can be corrected to factory spec, and can cause terrible handling, wear, and tracking problems.
YMMV
Old Jul 2, 2004 | 04:29 AM
brado's Avatar
new wheels = old school
hey beetroot, if you brought your CL into Bell Acura today, i saw it. i cant view the pics because it says the user exceded their view limit or something. there was a white cl with custom mesh grill and custom system there today. when i was looking at it from the side, i thought you totally had coilovers because it was sooooo low. now i know its a comptech drop, which i see all the time at work, and yours is def waaay lower than everyone elses comptech drop. anyways, car looks great and good luck with your car probs.
Old Jul 2, 2004 | 06:34 AM
Bluto's Avatar
Sounds like the wrong springs. Or the installer did something wrong. Beetroot, you have part # 110-135 ?
Old Jul 2, 2004 | 10:10 AM
BEETROOT's Avatar
Yeehaw
yeah that was my car.
I bought my springs from someone on here....can't remember who. I wonder if they screwed me and sold me some other kind of springs
I never even opened the box I just dropped my car off at the shop and had them put them on.
shit.
Old Jul 2, 2004 | 10:18 AM
BEETROOT's Avatar
Yeehaw
hey brado -
right in front of where my car was parked at the end of the day, there was a white 04 TL with navi. the sticker on it was $29,xxx. the price on that car at www.acura.com is more like $34,500.
any idea why it was so cheap? are all the TL's going so low?
Old Jul 2, 2004 | 11:10 AM
RUPNOK's Avatar
'08 TL-S
I'm not a mechanic but it was explained to me like this (someone who knows please correct me if I'm posting crap)...
Rotors warp b/c they overheat and lose their temper. You can cut the rotors to smooth them out but the temper's gone and they'll warp again; also when you cut them you remove metal and since they have less mass they heat up quicker (less resistant to overheating).
So the only real fix is to replace the rotors.
This happened to me; dealer cut the rotors under warranty, which bought them some time until they warped again; by then the car was off warranty and I had to cough up for new rotors.
So I'd demand new rotors if you're under warranty. Don't let them try to give you a half assed fix for a problem that so many of us have w/our brakes.
Old Jul 2, 2004 | 11:13 AM
BEETROOT's Avatar
Yeehaw
the warped rotors are only covered under warranty if the original brake pads have a certain degree of wear. mine were beyond the cutoff, so the rotors were not covered by warranty. I called a couple dealers about this and they both told me the same thing.
I had the rotors cut, and there is a 12 month warranty on the work so if they warp again I'm covered.
Old Jul 2, 2004 | 01:18 PM
evilstorm's Avatar
im having the same vibrations from braking...probably the same problem..how Should i just get them replaced at the dealer or get rotora slotted or regular or what? im confused now
Old Jul 2, 2004 | 06:20 PM
EricL's Avatar
Can you also have them check the run out of the hub? (Just in case).
Whatever you get, make sure to get the "bedding in" info for the pads -- it really helps.
Some slotted, or x-drilled and slotted would be fine -- your choice. If you're going to have to get the work done, you could find some relief with some good rotors and some good pads...
The threads have lots of info in them…
Old Jul 2, 2004 | 06:34 PM
EricL's Avatar
I have some disagreements with some of their comments, but you might want to take a look a this:
http://www.ceramicbrakes.com/whitepa...otors_myth.htm
Iron can have uneven deposits of carbon, and it might be around 1- to 2-percent.
Another excerpt:
What causes 'Warped Rotors'?
Typically warped rotors are caused not by a failure of the rotor itself.
Warped rotors (in most instances) are caused by the brake pads being operated at temperatures outside of their specified range. When the pads get too hot the pad material actually melts and 'fuses' itself to the rotor surface and creates a 'bump' on the surface of the rotor. In most cases this is not noticeable to the naked eye. This creates an annoying vibration when the brakes are applied. The only solution to this is turning (grinding) the rotors or installing new rotors.
We do not recommend turning rotors: It removes additional metal and reduces the the thermal capacity of the discs.
The best way to combat this condition is to use GOOD QUALITY street performance brake pads which have a higher operating temperature range.
Properly 'bedding-in' the pads and discs is a must.
BTW, just having someone over torque the wheels and do it in a "messy" fashion -- no start pattern used to gently raise the torque to insure uniform torque distribution over the whole rotor/wheel/hub assembly, is asking for future brake trouble.
And, I've had only one set of rotors that seemed "cursed" -- they were made from some poor iron (this is what I gathered) that I tossed them when they started to warp after bedding them in. They were even ground, not lathed, but that was the exception.
And, a SAE paper titled: "Introduction to Gray Cast Iron Brake Rotor Metallurgy"
http://www.sae.org/events/bce/tutorial-ihm.pdf
Hard to make up rules about "iron" when you think about it...
