Car Fax Please?
Moderator Alumnus
well, thats the first sign that it might be a scam or something, or maybe its an honest mistake...I copied the VIN exactly as its listed.
I'll contact the seller directly for verification, thanks for checking.
Moderator Alumnus
cl-driver, can you work your magic? I'm also going to try Jesals link to see what happens - JF1GD29692G501832
has Gloryhole Girls in
1 Post
The CARFAX came back and...
The car has had 11 major accidents, has been involved in 3 manslaughter cases...all convicted, was a prior rental and also showed odometer fraud in three different states. It shows salvaged/flood title and is currently registered in guantanamo bay to a gentleman named acpui faltaharam.
good luck with your purchase
I assume you got the carfax already but here ya go.
Vehicle Description JF1GD29692G501832 2 Historical Records Found on This Vehicle
TitleCheck 0 records found
ProblemCheck 0 records found
OdometerCheck 0 records found
Vehicle Information 0 records found
Full History 2 records found
This Vehicle Qualifies as AutoCheck Assured.
The Vehicle Identification Number (VIN) you submitted has been analyzed and summary detail information on your car is shown below.
VIN: JF1GD29692G501832
Year: 2002
Make: Subaru
Model: Impreza WRX
Style/Body: 4 Door Sedan
Engine: 2.5L H-4 MPI SOHC Tbo
Country: Japan
Key: = No Problem Found = Problem Found = Information Found
Your Vehicle Checks Out! AutoCheck's database for this 2002 Subaru Impreza WRX (JF1GD29692G501832) shows no significant Title events. When found, events often indicate past automotive damage or warnings associated with the vehicle title.
Titles Checked: Results:
Abandoned No Abandoned Record Found
Damaged No Damaged Record Found
Grey Market No Grey Market Record Found
Hail Damage No Hail Damage Record Found
Insurance Loss No Insurance Loss Record Found
Junk No Junk Record Found
Odometer Problem No Odometer Problem Record Found
Rebuilt/Rebuildable No Rebuilt/Rebuildable Record Found
Salvage No Salvage Record Found
Water Damage No Water Damage Record Found
Your Vehicle Checks Out! AutoCheck's results for this 2002 Subaru Impreza WRX (JF1GD29692G501832) shows no significant problems. When found, events often indicate past automotive damage or warnings associated with the vehicle title.
Problems Checked: Results:
NHTSA Crash Test Vehicle No Crash Test Vehicle Record Found
Frame Damage No Frame Damage Found
Major Damage Incident No Major Damage Record Found
Manufacturer Buyback/Lemon No Manufacturer Buyback/Lemon Record Found
Recycled No Recycled Record Found
Salvage Auction No Salvage Auction Record Found
Your Vehicle Checks Out! For this 2002 Subaru Impreza WRX (JF1GD29692G501832), no indication of an odometer rollback or tampering was found. We gauge for odometer rollbacks by searching for records that indicate an odometer reading that's less than a previously reported value. Other odometer events can report events of tampering, or possible odometer breakage.
Date Reported: Odometer Reading:
Your Vehicle Checks Out! AutoCheck shows a clean record for this 2002 Subaru Impreza WRX (JF1GD29692G501832). For some cars, past vehicle information may give indication of excessive wear and tear, such as with police cars or taxis use.
Vehicle Information Checked: Results:
Accident Data No Accident Data Available
Corrected Title No Corrected Title Record Found
Duplicate Title No Duplicate Title Record Found
Emission/Safety Inspection No Emission/Safety Inspection Record Found
Fire Damage No Fire Damage Record Found
Lease No Lease Record Found
Lien No Lien Record Found
Livery Use No Livery Use Record Found
Government Use No Government Use Record Found
Police Use No Police Use Record Found
Rental/Fleet No Rental/Fleet Record Found
Repossessed No Repossessed Record Found
Taxi Use No Taxi Use Record Found
Theft No Theft Record Found
Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be highlighted.
VIN: JF1GD29692G501832 2002 Subaru Impreza WRX
EVENT
DATE EVENT
LOCATION ODOMETER
READING DATA SOURCE EVENT DETAIL
2002-10-30 CLEMSON,SC Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
2003-11-24 CAYCE,SC Motor Vehicle Dept. TITLE
Title #: 770760119511318
AutoCheck Vehicle History Report Disclaimer:
Experian's Auto History Report is compiled from multiple sources. It is not always possible for Experian to obtain complete discrepancy information on all vehicles, therefore, there may be other title brands, odometer readings or discrepancies that apply to this vehicle that are not reflected on this report. Experian searches data from additional sources where possible but all discrepancies may not be reflected on the Auto History Report.
THESE REPORTS ARE BASED ON INFORMATION SUPPLIED TO EXPERIAN BY EXTERNAL SOURCES BELIEVED TO BE RELIABLE BUT NO RESPONSIBILITY IS ASSUMED BY EXPERIAN OR ITS AGENTS FOR ERRORS, INACCURACIES OR OMISSIONS. THE REPORTS ARE PROVIDED STRICTLY ON AN "AS IS WHERE IS" BASIS, AND EXPERIAN FURTHER EXPRESSLY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE REGARDING THIS REPORT.
Experian shall not be liable for any delay or failure to provide an accurate report if and to the extent which such delay or failure is caused by events beyond the reasonable control of Experian including, without limitation, acts of God or public enemies, labor disputes, equipment malfunctions, material or component shortages, supplier failures, embargoes, rationing, acts of local, state or national governments, or public agencies, utility or communication failures or delays, fire, earthquakes, flood, epidemics, riots and strikes.
Year: 2002
Make: Subaru
Model: Impreza WRX
Country: Japan
EVENT
DATE EVENT
LOCATION ODOMETER
