Car is acting up Video inside
Old Jun 26, 2007 | 09:07 PM
JBlueCLS6's Avatar
First. the car was stalling out every so often when in stop-n-go traffic or idle rough as if it were about to stall. CEL would start flashing whenever it was about to stall then adjusted itself.
I unplugged the battery and to reset the CEL and now the car stalls out anytime I put it into neutral. I have to Rev the car while driving to keep it from stalling out.
http://www.youtube.com/watch?v=Wypn5nB441w
The vid might take a bit to get up since I just uploaded it.
Old Jun 26, 2007 | 09:21 PM
fuzzy02CLS's Avatar
Did you read the codes? That's step 1.
Old Jun 26, 2007 | 09:59 PM
SIRSIG's Avatar
THE J35A2...
that fucking squirrel again!
Old Jun 26, 2007 | 10:24 PM
INSPIRE 32V's Avatar
Glacier Frost Mica CL-S
having a similer problem
Old Jun 26, 2007 | 10:37 PM
CL FWD SPEED's Avatar
What to do, what to think
Have you changed or clean the IAC valve? but agreed with fuzzy02CLS check out the CEL code see whats up. take it to AutoZone for a free diagnosis
Old Jun 26, 2007 | 10:43 PM
JBlueCLS6's Avatar
My CEL is off now since I disconnected the battery. Hasn't came back on. I'll try cleaning it tomorrow.
Old Jun 27, 2007 | 02:30 AM
mrsteve's Avatar
Do you happen to have the A/C running while this happens?
Old Jun 27, 2007 | 02:32 AM
mrsteve's Avatar
Code is probably a too rich code or a random misfire.
Your IAC is toast. Replace it or try adjusting it as I showed you in the previous thread.
I had this problem too although I never actually stalled but my RPMs would drop to 500 and the car would shutter after reving like that.
Old Jun 27, 2007 | 09:57 AM
Moodist's Avatar
Any reason you ask if the a/c was running? I notice the RPMs dip at idle when the a/c is on.
Old Jun 27, 2007 | 10:04 AM
JBlueCLS6's Avatar
AC wasn't on. I'm gonna be taking it apart this afternoon to clean it and adjust it and if that doesn't work I got an appointment with Acura next Thursday and hopefully the IAC valve is covered under warranty if it needs to be replaced.
Old Jun 27, 2007 | 01:24 PM
mrsteve's Avatar
The extra load will cause these symptoms or if the symptoms always exist make the problem more prevalent.
Old Jun 27, 2007 | 02:52 PM
Misdby1's Avatar
damnit, now theres partially chewed peanuts all over my computer screen...
Old Jun 29, 2007 | 09:33 AM
JBlueCLS6's Avatar
Bump here were the codes
PO 301- through 306
Misfire on all Cylinders
PO-1399
Old Jun 29, 2007 | 11:17 AM
mrsteve's Avatar
Well PO 301-306 is misfire on cylinders 1-6 and PO 1399 is a general ignition system or misfire code
Old Jun 29, 2007 | 12:29 PM
JBlueCLS6's Avatar
What can be possible causes for the error codes? I've looked back into a few threads that stated EGR, the cat. Anything I should particularly check?
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
Jpro
Sep 13, 2015 07:14 PM
Aug 30, 2015 02:39 PM
