Can I use this supercharger
Old 08-04-2009, 01:48 PM
  #121
3.7L Nitrous Breathing CL
richardparker's Avatar
I am running the 5auto.Last week I thought there was going to be a problem starting with it,but I guess it was a fluke slip or something.I've sprayed it about 8 times so far only holding it for a few seconds.Like from first to 3rd.I also tryied it at passing speed once.The transmission actually feels great as if it shifts quicker with no delay.Brfore the car would grab 2nd about 85-90% of the time.Now it spins atleast 5-10feet in 2nd everytime.It actually feels like I'm driving a decent stock v8 when spraying.I am only using a 65 shot.I will be uping the shot next time I fill the bottle some where between 80-100.I dont want to go over a 100 cuz I dont want to prematurly kill my engine.
Old 08-04-2009, 03:13 PM
  #122
p.diddy's Avatar
arent you doing that anyway just by having the spray in the first place?
Old 08-04-2009, 03:35 PM
  #123
probally a little extra wear with the 65 shot.I would not say much at all.With the 65shot my feeling is I could use it for quite awhile before killing the engine since I do maintain the engine pretty well.But going over a hundred you should use a hi flow fuel pump so you dont max out your pump and run to lean,witch is bad and also I do not have at the time.
Also going over a 100 shot you should retard the timing atleast 4 dergress and more.Witch you need some kind of computer management/piggy back controler that I also do not have.I think I'm totally safe at 65.There will be more go fast parts going on soon.
On another note,I've been looking to changing the final gear and some way to increase the rev limiter. I have'nt had any luck finding anything for either of these.Anyone have any idea's ?
Old 08-04-2009, 05:34 PM
  #124
wham bam thank you ma'am
Rajca's Avatar
the only way to change the final gear ratio is to put in a new gear in the trans. to raise the speed limiter, u would need to reflash the ecu.
if u know what ur doing with nitrous, it doesnt cause any more damage than a turboed or sc car. u just have to be careful on what ur doing
Old 08-04-2009, 06:04 PM
  #125
slow tl..
gfrg88's Avatar
VIDS!!
Old 08-04-2009, 06:07 PM
  #126
I have not been able to find anyone that does the final gears for our trans,Ive been looking.
Where would I get the ecu reflashed like your talking about? thanks
Old 08-04-2009, 06:09 PM
  #127
Rajca's Avatar
have no idea where to get the reflash.
Old 08-04-2009, 06:13 PM
  #128
Originally Posted by gfrg88
VIDS!!
I did actually make a video last night,but I had the cammera recording on the dvd not the sd card.When my cammera records on the dvd it wont transfer to the computer.Why I dont know.I'm kinda pissed cuz I made one with my subs pounding to infront of a redbox at wallgreens.To show people on a differnt site how my subs make the box and the metal awnings rattle that are on the building.I will get one for you thou.
Old 08-04-2009, 06:14 PM
  #129
How and where have you heard about getting our ecu reflashed ?
Old 08-04-2009, 06:17 PM
  #130
Rajca's Avatar
never heard anyone reflash the ecu on a cl/tl. but thats the only way. its been done on other cars.
or
u can take out the speed sensor/ rev sensor on the trans, but then u wont know how fast ur going or what will it actually do to the car.
Old 08-04-2009, 06:31 PM
  #131
Pulling sensors really dont sound like the best idea,Unless someone has really accomplished it with no alternative problems.
I will be asking around about the reflashing the ecu.
What about a ecu from a type s auto.I know I compared them before and all plugs seem to match up,but I was talked out of trying it.What do you think about that.
Old 08-04-2009, 06:51 PM
  #132
Rajca's Avatar
still has the same limit. the 6spd speed limit is 148-149mph. they autos is 152-155mph. i got to 153-154mph in my tl-s, took a while but i got their.
Old 08-04-2009, 07:17 PM
  #133
Not for the top speed limiter,for the rev limiter.
Old 08-04-2009, 07:20 PM
  #134
Rajca's Avatar
yes, never thought about it that way. so reflash is the only option and no one has done it. but where are u going to be going 150mph constantly or higher?
Old 08-04-2009, 07:28 PM
  #135
Not sure if we are on the same page.First, you know I have a clp?
Now ,I know type s's rev higher before hitting the rev limiter.So my question is, do you think its possible for me to use a type s ecu and I would gain the extra rpm's before hitting the limiter? I'm almost certin they have matching harness plug inputs.
Old 08-04-2009, 07:37 PM
  #136
Rajca's Avatar
wouldnt matter. i was in 4th gear a few hundred rpm before i hit the rev limiter. instead i hit the top speed and it cut the fuel. also the type s ecu wouldnt work properly, the engines are a bit different and the sensors wouldnt match up.
plus, all that for only, what, 200rpm or so
Old 08-04-2009, 08:47 PM
  #137
I think the j series ecu flash is not a option at all.Ive looked everywhere
Old 08-04-2009, 08:53 PM
  #138
Rajca's Avatar
its not, and i dont think that its possible. that or i dont know of any company trying to do it. now with all the j's going into civics and tegs, their might be some hope
Old 08-04-2009, 09:12 PM
  #139
Hondata has said theres no plans on doing anything for the J series and there probally are best chance.There has to be a some one that can reprogram our ecu.Maybe Bill Gates team of computer masters.
Old 08-04-2009, 09:44 PM
  #140
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,323 Likes on 4,900 Posts
There are two shops working on a reflash, and one supposedly has successfully completed it.
I spoke with Hondata as well, and they are being thick headed with this. They dont realize the amount of J swaps that are being started and how many people need some sort of management.
AEM realized this and they will be offering their EMS in the next few months. Its based off of the S2000 program, but they had to wait to do it because they were about to push Version 2 for the S2000s, and thats what they are going to use for the Js. They are planning on making it PnP, and they have already tested it in a J32 swapped 7th gen Accord. Expect to pay ~$1300 for it when it does finally come out.
Old 08-04-2009, 10:07 PM
  #141
Is this going to be a custom tuneable ems with differnt levels for each cl needs or is it going to be one set ems.After reading a little today the 03 cls 6 would have to be differnt than just 01-03 cl's right. If I sound like a idiot in anyway excuse me.I'm just trying to learn how bringing my car into the next level.
Old 08-04-2009, 10:26 PM
  #142
After the $1300 AEM EMS the car will permently hold the tune.This will be totally new for the public.Have they done any testing far as longevity of there product.Any warrenty? $1300 is no joke if it dont last.
Old 08-05-2009, 10:55 PM
  #143
What is good bottle pressure with no bottle heater?The last time I looked at the gauge it said 900psi after spraying it about 12 times for about 3-5 seconds each time.I never looked at what the pressure was when I first got it filled.
Old 08-06-2009, 04:44 AM
  #144
Rajca's Avatar
i keep my bottle pressure between 900-1100. thats the sweet spot, if u go lower ur not getting the full potential of the spray and just wasting nitrous.
Old 08-06-2009, 11:14 AM
  #145
Thanks man helpful as always.
Are me and you the only one's spraying?
Old 08-06-2009, 12:16 PM
  #146
Rajca's Avatar
Np. Don't forget to purge the lines when ur dons spraying. I haven't heard of any other cl's that are on spray. I know that their is a tl on 125wet shot that messed up his exhaust or intake valves bc he was misfiring and still didn't stop spraying. His fault.
Old 08-06-2009, 01:04 PM
  #147
To purge our setup with no purge,you just shut off the bottle and activate it right?
Old 08-06-2009, 01:07 PM
  #148
3.5 psi
gnuts's Avatar
Parker, why don't you look buying a CL-S engine and stroking it. Or a 6speed swap. You have a CL-P so you're already lacking power, plus it's an auto and there are tranny issues. Just seems a bit pointless to me. If you want to make serious power, then do the 3.5 conversion and put type S heads on it.
Old 08-06-2009, 01:35 PM
  #149
If I plan on keeping the car permently I will probally get crazy with the car.I'm not sure yet,so for now its just going to be bolt ons.I just love the 2nd gen RL's
Old 08-06-2009, 03:08 PM
  #150
Rajca's Avatar
Yup
BoricuaTL
04-08-2016 01:08 PM
Joe Avesyan
09-29-2015 03:57 PM
k6biv
09-22-2015 02:06 PM
2G-TL-Type-S-03
09-20-2015 12:48 AM
simplyjayyy
2G TSX Performance Parts & Modifications
09-02-2015 12:57 PM
Quick Reply: Can I use this supercharger
