Can a coil be tested?
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I have a "check engine code" It is for a #1 cylinder misfire.
I am going to replace the plug first.
If that does not cure it, then replace the coil.
My question is this.
Can the coil be tested to see if it is bad?
If so, how?
Thanks.
If so, how?
Thanks.
Before you replace anything, swap the coil pack with one from another cylinder....clear the code....and see if the code follows the coil pack. That will tell you if it is bad.
Or you can test it with a DMM (digital multimeter) set to resistance/ohm mode. I forget what the typical reading should be, but test it along with the rest of them and see how they compare. If the suspect pack reads significantly different, then it is probably bad.
Don't just needlessly replace parts....do a little troubleshooting first.....it could save you some money and you'll learn something as well.
CL-Pride
Originally Posted by o1s
or just pull the plug and coilpack crank it up and see if it fires when the engine runs. i like old fashion testing.
B A N N E D
usually a bad coil pack will make ur car run very poorly. it would run like a tractor. and the car would sound differently, and would have extra vibration due to misfiring
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
