Camber question (help please)
Old Jun 21, 2001 | 09:24 PM
CLpower's Avatar
teh Senior Instigator
how do i know what degree i will need? I'm down a little more then 2" and theres 2 kits. One that can adjust me up to 1.75 and one from 1.75-3.25. Which one do you think i should get?
Old Jun 21, 2001 | 09:32 PM
vuduvida's Avatar
An alignment would tell you how much negative camber you have. At least you'd know exactly which kit to get that way. I'd bet the first kit (< -1.75) would work though. You could also try to estimate with a plumb line and a protractor. (that should be fun)
'01 Blk/Blk CL-S, H&R OE Sport springs, K&N panel filter, Red Line 5W30
"Paradise is exactly like where you are right now... only much, much better."
Old Jun 22, 2001 | 12:46 AM
Jens H.'s Avatar
retired
You will need to have the car aligned first o see how far the camber is out,then based on that information you can decide which camber correction kit will be required to correct your car.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA high beam headlamp system H.I.D. Xenon low beam tinted, custom taillites and on and on
Old Jun 22, 2001 | 01:22 AM
4pumpedCL's Avatar
Honkey
Can't you just get the adjustable camber kit, install it, then take it to the alignment shop and have them dial it all in?
2001 CL-P, new project undergoing complete reconstruction. As of now: Custom CAI fabricated by SRD, Polarg M6 bulbs, 4 ProHopper Chrome hydraulic pumps with whammy tanks, 4 ProHopper dumps, 4 Optima marine deep-cycle batteries, 4 switches. Much much more to come...
1997 Accord coupe EX-L. Chrome suspension, Chrome motor, every bolt-on imaginable. One pump, 8 dump hydraulics with accumulators. Leather, Billet grills, 18" Neeper Shadows...etc..etc http://www.artofnoize.com/Cars/aaron.htm
1990 Toyota standard cab. Bodydropped 3". 17" KMC Nemesis', extensive suspension work. 4 wheel airbags.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
lanechanger
Oct 13, 2015 10:56 AM
navtool.com
Sep 25, 2015 05:15 PM
0opie
Sep 22, 2015 04:15 PM
