Which Camber Kit?
Which Camber Kit?
I just came back from getting my alignment and they said I needed a rear camber kit. Now I need to find find. So, can someone tell which one to get. Thanks
I picked up the Eibach Camber Kit made by Specialty Products from Tim. $174 plus shipping for the rear.
http://www.autocarparts.com/search/r...ignment%20Kits
How bad is your rear camber really? A little isn't gonna wear too terribly, especially if you rotate your tires. The camber kid can be self-defeating on the CL - if you're low enough to REALLY need it, putting it on will straighten the wheel out to the point where it's gonna rub so you just gotta raise it back up again. And when you raise it up, you no longer need the camber kit. It's a circular jerk.
I just order speciality product part# 67090 - rear camber kit from the groupbuy for $139 shipped. It is best price I found and is the same as the Eibach kit.
Here is where I go to part number: http://www.specprod.com/PROD_DIR/PROD_PASSCAR.html
I had the Ingalls Kit #3872 installed on the rear of my car today!!! It does camber and better toe adjustment. It replaces two of the rear control arms. It is awesome. The guys at my shop really liked it!!! The did my alignment and said it was easy to get the camber back - .5 degrees. Toe was 1mm in. I got mine from Tim at ACP and it cost me $244 shipped, and WELL worth it!!!! No goofy washers. Here is a link to the Ingalls site and a pic of the set I got. ===> CLICK HERE <===
I will post pics as soon as I get a chance.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
