Camber kit
Camber kit
If I recall...I've seen a rear camber kit, but does anyone make a front camber kit for the 2001 CL? Thanks
-Aaron
2001 CL-P, new project undergoing complete reconstruction. As of now: Custom CAI fabricated by SRD, Polarg M6 bulbs, 4 ProHopper Chrome hydraulic pumps with whammy tanks, 4 ProHopper dumps, 4 Optima marine deep-cycle batteries, 4 switches. Much much more to come...
1997 Accord coupe EX-L. Chrome suspension, Chrome motor, every bolt-on imaginable. One pump, 8 dump hydraulics with accumulators. Leather, Billet grills, 18" Neeper Shadows...etc..etc http://www.artofnoize.com/Cars/aaron.htm
1990 Toyota standard cab. Bodydropped 3". 17" KMC Nemesis', extensive suspension work. 4 wheel airbags.
-Aaron
if you dont mind answering a dumb question.. what is a Camber kit ?
2001 Silver 3.2 CL-P
Tints, piaa road lamps, hyper white all around, custom eyebrows, tl-s cup holders, Acura-CL.com stickers, '10 Xplod sub and AMP
Camber is one of the angles referred to in suspension systems.The most commonly referred to angles are camber caster and toe.When a vehicle is lowered such as ours these angles are changed due to the lowered ride height and adjustments must be made to compensate for this.Acuras typically do not feature an adjustable camber on either the front or rear suspension so the aftermarket has come into play and produces various replacement suspension parts that have adjustable components that allow the geometry of the supension to be setup properly.Comptech is testing an adjustable front upper control arm at this time but as of yet has not released it.I believe Eibach like most other suspension companies actually buy their camber arms from Ingalls.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA high beam headlamp system H.I.D. Xenon low beam tinted, custom taillites and on and on
Jens,
Does the 2001 CLS need a camber kit when springs only are installed?
Miss "Jackie Black" Black on Black 2001 CLS | Tint | airbox gutted | resonator replaced by straightpipe (mistake) | 12" JL Audio sub | PIAA 19170s | spoiler | mobile 1 | 14.6185 at 96.09mph 1/4 mile
work is the curse of the drinking class.
didnt we talk about this before??
Ingalls have camberkit for our car like a while ago. Front and rear
for about $260 for 4
i was gonna get it, but a lot of myf riend told me it s kinda uesless.. because it only adjusts up to 3 degrees,, and once, u run over a rock or a dip.. then u need to ajust it again...
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
