Camber issues with Comptech springs (Jens?)...
Just got the Comptech springs installed on Sat and had an alignment today. Toe was out in the front, but it's fixed now. However, the rear camber on the right side is out of specs by 0.1 degrees and they told me the right rear tire will wear unevenly.
Has anyone else had this problem? What were your rear camber results?
My rear camber
Left rear
Actual: -0.9 degrees
Before: -0.8 degrees
Range: -1.0 to 0.0 degrees
Right rear
Actual: -1.1 degrees*
Before: -1.0 degrees
* This one is out of specs
Are these numbers good? BTW, my headlights were still aligned (no adjustment needed) after the new springs were installed.
2001 Acura 3.2CL Type-S
Satin Silver/Ebony
No Navi
No Badges
Competch springs/35% tint/Wheel locks/Splash guards/PIAA 19169 bulbs/K&N 33-2178 air filter/Mobil-1 5W-30 oil & filter/Shine by Meguiar's/One scratched rim
My rear camber
Left rear
Right rear
Satin Silver/Ebony
No Navi
No Badges
My numbers were exactly the same as yours. 0.1 is not really out of spec. Most specs have a tolerance on the low side because engineers (including myself) will always protect our hinnies. I have 3k miles without any excessive wear. How was the Goodson service dept?
<font face="Verdana, Arial" size="2">Originally posted by fender4:
</font>
</font>
Satin Silver/Ebony
No Navi
No Badges
</font>
</font>
BTW, thanks for the info. I was a little worried because it was out of specs, but had a feeling that there was a fudge factor. When I was in the Air Force, everything on our aircraft had a fudge factor to it. But, that factor is there for a reason.
Satin Silver/Ebony
No Navi
No Badges
Jens did the install and alignment on my car and said my car's left rear wheel was off about the same. I've been checking the wear and so far so good but rotating the tires more frequently is something that should help this. Also installing camber kits is an option although I forget if Comptech's camber kit is only for front or rear. I hope they are for rear because if memory serves wayneg (Park Ave manager) said that fronts probably wouldn't need any camber correction.
"01" CL Type-S
White\Black
Comptech Springs
Comptech Sways
Navigation System
Burlwood Shifter
Guards+Fenderwell Trim
PIAA16969
Smokers Package
My Car
"01" CL Type-S
White\Black
Comptech Springs
Comptech Sways
Navigation System
Burlwood Shifter
PIAA16969
Smokers Package
My Car
.1 of a degree seems to be the typical number that comes up with Comptech springs and as such is not something I would worry about.Granted I would prefer to see the car below 1.0 degrees camber but this is not attainable with lowering springs unless you install camber correction kits.For now keep an eye on the inside edges of your rear tires should any wear become apparent then it is time to proceed to camber kits.By the way Comptech sells rear camber kits at this time and is working on a front camber kit.If your camber in the rear approaches or exceeds 1.5 then you will definitely see tire wear but at 1.1 you should be alright.Increase you tire rotation schedule a bit to help matters along.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA high beam headlamp system H.I.D. Xenon low beam tinted, custom taillites and on and on
<font face="Verdana, Arial" size="2">Originally posted by Al Uminum:
</font>
</font>
Satin Silver/Ebony
No Navi
No Badges
<font face="Verdana, Arial" size="2">Originally posted by Jens Heydel:
</font>
</font>
Jens - First off, let me say that I am very impressed with you knowledge and patience when dealing with all of our questions and concerns! I sure wish other mechanics from around the country would take the time to do the same.
I will keep an eye on the tire wear and plan to have them rotated every 6000 miles now instead of 7500 (unless it's needed sooner).
Thanks again!
Satin Silver/Ebony
No Navi
No Badges
You're welcome.I have to agree on the price of the correction kits seems steep then again consider the price of new tires.I look at it this way although it is an expensive way to go it is also a one time deal once they are in the car your tires will benefit long term which in turn means less money spent long term.But for now just keep an eye on things and see if a problem develops.Jens
How much are the camber kits going for right now? I know im definitely goign to need a front and rear pair...cuz those eibachs really screwedup my camber. I dont particularly want to go comptech since they like to kill anyone on prices...are there any other kits out there?
01' CL 3.2 Premium.
Tan/Black
Neuspeed Strut Bar
Diamond Nicrome Limo Mirror Tint
Undetectable K40 w/t Diffuser
Kicker 12" Competition
Cleared Headlights
Custom Int/Ext Lights
Comptech Sway Bars
AEM CAI w/t Bypass Valve
Eibach Pro Kit
Denso Iridium Spark Plugs
01' CL 3.2 Premium.
Tan/Black
Neuspeed Strut Bar
Cleared Headlights
Comptech Sway Bars
Eibach Pro Kit
Do i really have to spend like 700 just to fix my freaking camber? CHecked auto car parts and the kits are so pricey and then you have installs....
01' CL 3.2 Premium.
Tan/Black
Neuspeed Strut Bar
Cleared Headlights
Comptech Sway Bars
Eibach Pro Kit
01' CL 3.2 Premium.
Tan/Black
Neuspeed Strut Bar
Cleared Headlights
Comptech Sway Bars
Eibach Pro Kit
oh goodie.
Speaking of Camber & alignment.
Can the stock CL-S rims/wheels fit on the Premium model?
Will rubbing be an issue?
Will adjustments have to be made?
- Kvit -
2001 CL-P Monterey Blue, Parchment interior
• Polarg BlHybrid M-6 Road lamps
• Polarg/PIAA super white interior lights *bling bling*
• HP Quantum 28 -- 31% metallic tint all around
• Planning: 17" rims w/ Bridgestone Potenzas (730),
Comptech Springs & Sways, V1
• [Photopoint Album Pics]
• [So.Cali. Nite Meet 5/17: Tustin Black Angus Pics]
• [So.Cali. Nite Meet 5/17: Tustin Black Angus Pics II]
Other
• [Yamaha Home Theater Gear]
• [DVD List]
• [June 3rd Sunday Cali. BBQ: Irvine Park]
[This message has been edited by KavexTrax (edited 06-04-2001).]
- Kvit -
Other
• [DVD List]
Kavex,
They should fit no problem.
Spiro
Black/Black 2001 CL-S
Random Technology Cat
RED AEM CAI
Polarg M6 Roadlamps
Spiro
<font face="Verdana, Arial" size="2">Originally posted by KavexTrax:
oh goodie.
</font>
oh goodie.
</font>
RED AEM CAI
Polarg M6 Roadlamps
<font face="Verdana, Arial" size="2">Originally posted by P-Man:
Mike - how much did Goodson charge for the labor? Did you buy the parts from them also?
</font>
</font>
Satin Silver/Ebony
No Navi/No Spoiler
Competch springs
35% tint
PIAA 19169 bulbs
The Aviation Zone
[This message has been edited by MikeN (edited 06-04-2001).]
<font face="Verdana, Arial" size="2">Originally posted by MikeN:
All Goodson did was the alignment, which was $59 (they matched Vandergriff). I ordered the springs from http://wwwAutoCarParts.com/ and had them installed by Jotech in Garland.
</font>
</font>
Black/Parch '01 CL-S no-navi, Spoiler, Visor, 35% tint, wheel locks, PIAA19169 fog lights.
so what did jotech charge for the install?? how did you like them?
</font>
</font>
They did a good job. Took about 1.5 hours and they charged me $150. Although, they have been charging others $200.
Ask avengerjr where he got his put on, they did it for $150 and he said they were excellent.
Satin Silver/Ebony
No Navi/No Spoiler
Competch springs
35% tint
PIAA 19169 bulbs
The Aviation Zone
Yo Yo Yo...peep this...yeah right, like I talk like that!
P-Man, I got my H&R OE Springs from a friend on the TL board, not Tim (snook), paid $130 total (including shipping) for them.
Got them installed at Intercrew in Richardson for $150 (hookup), but I don't think they would charge much more than that. Install took about 3.5 hours, .5 hour wait while finishing up another car in front of mine, a civic getting a shortshifter. They are very detailed and make sure it is done right. So I didn't mind the extra wait time, because everything exceeded my expectations!
I would highly recommend them, and if you mention my name, well you get nothing, but hey what do you want from me!
avengerjr
2001 CL-S Satin Silver / Ebony Interior / Non-Navi[*] spoiler , wheel locks , 35% tint , fenderwell trim[*] mud guards , winter floor mats , full nose mask[*] Xephyr CAI , H&R OE Springs
avengerjr
cool. thanks for the info guys. now all i need to do is buy the damn springs.
</font>
</font>
that way you can see mine side by side with MikeN's
Then we all will see the difference in person between the Comptech's and H&R OE's.
avengerjr
<font face="Verdana, Arial" size="2">Originally posted by avengerjr:
come to the lunch meet next thursday 14th, check it out in the events forum.
</font>
</font>
cycdaniel
Dec 17, 2019 10:58 AM
jmoney2001
Aug 12, 2019 06:23 PM
Barb Jackson
Sep 15, 2015 02:27 PM
k6biv
Sep 10, 2015 06:37 PM
