Camber alignment question
Old Jun 12, 2023 | 08:04 AM
Dat Guy's Avatar
Just purchased a CL-S and after going through the car, I am now doing some modifications. This will be the first car I’ve ever done some performance mods too, so some of this world is a new to me. Given the money I have to invest in this right now, I’ve decided to go with are a new set of Cooper RS3-G1 225-45-17 (payed 87$cdn/tire and couldn’t say no) on Oem 7” wide rim, H&R Sport Springs (on oem struts that were recently replaced by previous owner), Moog rear sway bar end links, and Progress rear sway bar from the 3rd Gen Tl-S. My questions are related to my alignment after lowering. Will I need to get either camber adjustable ball joints or adjustable arms for a 1.75” front and 1.5” rear drop given my tire dimensions? What toe and camber settings should I request when getting my alignment?
I know there is Eibach pro kit install write up a member did on here and he chose to install adjustable arms to solve his camber issue, but from what I’ve read, it seems like the drop on the Eibach is a bit more than the H&R. This makes me wonder if I can get away with what camber adjustment the car has in OEM form. Also, if I do need additional camber adjustment, is there a general consensus on if camber ball joints or adjustable arms are better on the CL?
Given where the car will be getting the alignment, I’d have more peace of mind telling them specific toe and camber values, rather then letting them decide. Given my mods and tire dimensions, what toe and camber values should I request?
Old Jun 12, 2023 | 08:11 AM
Dat Guy's Avatar
I should also mention that I’m looking for camber and toe values that reflect a fun daily driver. I don’t mind a little additional wear if the vehicle has better dynamics
Old Jun 12, 2023 | 09:37 AM
https://acurazine.com/forums/3g-tl-t...er-kit-606757/
Toe should be zero.
Old Jun 12, 2023 | 11:36 AM
Dat Guy's Avatar
I didn’t come across this article because I’ve only been searching the 2nd Gen TL and CL threads for info related to this topic. Thanks for this.
ezland00
May 27, 2009 10:44 PM
ABP_04TL
Nov 28, 2008 05:39 PM
Thorin78
Aug 25, 2005 04:25 PM
blo2ck
Mar 18, 2003 01:12 PM
X3.2CLSX
Jul 13, 2001 10:06 PM
