Calling All 2nd Gen Know It Alls
Originally Posted by GreenMachine
Where's the IMRC threads in the FAQ?
I've seen lots of members post "Look in the info thread noob" when I know for a fact that the answer isn't listed in the info thread.
In my defence, this whole info thread wasn't even my idea, but I'm stuck with it now
It's actually not that big a cross to bear...Lord Helmet had it covered on page #7...
actuator is another search keyword for it... so that's why the noob couldn't find it...
Originally Posted by Lord Helmet
It's the IMRC you need to check.
About...
https://acurazine.com/forums/showpos...1&postcount=18
https://acurazine.com/forums/showpos...5&postcount=23
Full thread about IMRC...
https://acurazine.com/forums/showthr...highlight=IMRC
See it working here...
http://www.geocities.com/gamesmgr/chod/acura/#Driving6
http://wizardsworks.org/chod/acura/pics/faq/actuator.rm
About...
Acura Factory Trouble codes (DTC's) (in pdf format):
http://www.in.honda.com/Rjanisis/pubs/SB/B03-010.PDF
I've got a bunch of acura TSB pdfs, that I need to go thru to see which ones pertain to the CL and then create a comprehesive list of 'em all... It's gonna take awhile to go thru 'em all tho'...
Tightening the power outlet next to the coin tray:
https://acurazine.com/forums/showthr...t=power+outlet
Need to get a bunch of links for the 105K maintenance (timing belt, etc):
https://acurazine.com/forums/showthr...highlight=105K
DIY for removing emblem gunk
https://acurazine.com/forums/showthread.php?t=188261
UniChips Direct hotline
https://acurazine.com/forums/showthread.php?t=189002
How many miles can be had when the gas light goes on (Post #22)
I think this is great information to have in the FAQ.
https://acurazine.com/forums/showthr...=183123&page=1
TL lip on a CL (CLTYPESLOW summer project):
https://acurazine.com/forums/ramblings-12/if-anyones-bored-will-provide-amusement-while-189897/
Trunk emblem badge letter placement measurement dimension:
https://acurazine.com/forums/showthread.php?p=2693878
Installing a Type-S intake manifold on a premium model engine.
https://acurazine.com/forums/ramblings-12/atrocities-taliban-read-187979/
6-speed Transmission drain/check/fill bolt locations and instructions:
https://acurazine.com/forums/showthread.php?t=188979
Can we add this thread to the FAQ? It's on the replaceable sway bar end links.
https://acurazine.com/forums/showthread.php?t=191709
Headlight ballast install:
https://acurazine.com/forums/audio-video-electronics-navigation-22/tv-navi-possible-191816/
Headlight helms scans:
https://acurazine.com/forums/showthr...dlight+removal
DIY on how to switch out the center console's arm rest"
https://acurazine.com/forums/ramblings-12/show-next-weekend-191841/
Need to add links to the SRS warrenty thread:
https://acurazine.com/forums/showthread.php?t=179416
I've been waiting till we hit page 10 before Updating the FAQ... so post up anything you think should be included.
Rear View Mirror Leaking Issue
https://acurazine.com/forums/showthr...light=exploded
Helped me a lot and I didn't see it in the info thread.
OEM pop-screws/plastic rivets cheap replacement:
https://acurazine.com/forums/audio-video-electronics-navigation-22/attn-streeteffectz-192746/
Originally Posted by GreenMonster
Need to find some threads on interior light bulbs (there are tons of threads here, but alot are crap).
I can take pics and write something up if its what you're looking for.
Ok, I've updated the Info thread:
https://acurazine.com/forums/showthread.php?p=2592079
I'm not really sure what format looks best.
The original: https://acurazine.com/forums/showpos...26&postcount=2
List format: https://acurazine.com/forums/showpos...17&postcount=4
Basic Text: https://acurazine.com/forums/showpos...79&postcount=5
I should really make 'em all consistent
underdrive crank pully belt specs:
https://acurazine.com/forums/car-parts-sale-361/wanted-comptech-header-02-tls-193723/
some sugestion
well is place call all data wich is one of the most use places for mechanics of course is not free at all for one year is like $29.00 but is great because not only yoou can find all the info of your car is a place there cal TSB (technical service bulletin) that one is like a recall
or before is a recall they tell you a recen problem and tell you how to fixed and how much the job should be,now i don't know if the r egular version would tell you the time to repair but sure they tell you the OEM .
now regarding this:
EVAP evaporative emission .. now in the cl is 5 wich one is inside the engine like the famous "purge valve the other 4 are under the car near the gas tank and are call:
EVAP purge valve
two way valve
solenoid valve
canister
canister shut of valve
IBA intake air bypass (control vavle)
IAC idle air control (valve)
IAT intake air temperature (sensor)
IMRC intake manifold runner control
well hope helps
now regarding this:
EVAP purge valve
two way valve
solenoid valve
canister
well hope helps
Really need to find some emanage and Apexi AFC Neo threads too (but I know nothing abotu that crap)...
https://acurazine.com/forums/showpos...6&postcount=30
