Bumper Cover alignment.
Old Mar 31, 2005 | 11:13 AM
Smitty's Avatar
Okay got an issue that I have not figured out..
maybe someone can shed some light on.
I removed the bumper cover so I could install the heat exchangers for my I/C...
after re-install I noticed a gap right under the grille... I do not like it all.. it is driving me nuts... I plan to pull the cover again this weekend... am I missing something here or does everyones look like this.??
Old Mar 31, 2005 | 11:19 AM
Jonesi's Avatar
I enlarged the pic to show a little more:
I'll take more pics later if needed.. Looks like your grill bent out a little..
Old Mar 31, 2005 | 11:20 AM
Smitty's Avatar
Maybe I am going crazy.... I could of sworn it was never like that...
here is a totally stock picture of my front end 1 month after I bought the car.
Old Mar 31, 2005 | 12:20 PM
Artwork's Avatar
DP's for life
Smitty-
I too am having the same issue...I pulled my front bumper off to measure my new grille's and when re-installing it I noticed that the bumper was sitting lower then it was before. I posted the thread but did not have pictures. Mine looks exactly like yours. I do not remember it looking that way before I pulled off the Bumper. Here is the thread I posted a couple of weeks ago.
http://www.acura-cl.com/forums/showt...t=front+bumper
I wonder if it has something to do with the brackets that are under the head lights. I tightened mine when I was trying to fix the issue, but it did not fix anything for me. I know that adjusting those bracket's does make a differance, but it did not resolve my issue.
After looking at your pictures of before and after if you look at the pilliars where the hood meets the bumper you will notice that the gap is now larger. I am having the same issue. Did you have to drill out any of the screws that hold your cover down in the middle of the cover? I had one screw that would not budge and I had to drill it out...it is the only other thing that changed on my install.
Old Mar 31, 2005 | 12:28 PM
mattg's Avatar
Old Mar 31, 2005 | 01:28 PM
phipark's Avatar
Not Asian
It does look lower. However, if you look at the seams on either side of the grill, the gap looks the same.
Old Mar 31, 2005 | 02:13 PM
chevyjase's Avatar
Your CL's got an overbite.... need to see an orthodontist.
My guess is you have dislogged some of the bumper foam causing the center to sag.......hard to tell without looking at it in person, best is to find anouther CL and do some comparisons or dismantle and try again. Good Luck
08KBP_VA
Oct 22, 2019 01:55 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
BIGxRED
Oct 19, 2015 10:47 PM
hashbrown
Sep 29, 2015 12:13 PM
rhdune16
Sep 28, 2015 11:31 AM
