Bulb replacement-Cruise switch
I have done a search and don't see the answer to this question: Do I have to remove the IP cover to get at this switch? I found a DIY for the cover removal, so I am covered if I have to do that. Thanks
Whats up with RDX owners?
You dont have to. You can take the lower cover off and push the switch out.
Lower corner? I meant the cover that is by your knees. Pop the fuse panel cover off then unscrew the one screw holding it on. The rest is clips. The you can push from behind on the switch and pop it out, then disconnect the harness. Easy peasy.
You kind of have to wiggle it out. The clips are pretty strong.
xsilverhawkx
09-28-2015 06:51 PM
