Broken seat heater
Broken seat heater
Does anyone know how much the dealer charges to fix the passenger seat heater in '03 CL-S? Also how hard is it to remove the passenger seat do to its motors? I have replaced seat covers before on my '99 Galant I had Katzkin interior made for the seats & door panels and installed it myself it wasn't that hard once I got the hang of it the hardest part was removing the old hog rings. Those were basic shaped seats the CL-S has more of a sport seat & I have a feeling it's gonna be a pain to re-attach the seat covers cuz of the higher bolsters so I'd rather have someone else do it if it's not ridiculously expensive.
Uses turn signals in my
As far as the passenger seat motors, are you talking about the reclining motor? If so I can give you a decent idea how on how to do that (it is pretty simple). It gets quite a bit more complicated if you have to replace the whole gear set for the recliner, but still doable.
I also had to do this, its not hard. If you're worried about re-fitting the leathers don't they go on without much trouble. All you need is the hog ring and hog ring pliers but it sound like you already do. Job took about 3 hours from start to finish.
Quarantuning
Happened to my seat last winter. Pulled off the Leather to find a burt wire with a big burn hole around it. It almost started to burn the Leather.
Fixed it without a problem but it was a pain in the ass for sure. The hog rings are brutal, and I had the correct pliers to use. Your hands will be so sore when your done.
Here's a tip that may help: One of my boys is a alarm, radio, navi, heated seat etc.. installer for a big dealership around here. He just cuts the hog rings pulls them out and re-installs the Leather with small zip ties. Says it saves him lots of time and pain.![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
