brand new rotora rotors warped?
1 Post
ok so I just posted this in the first gen forum, but since not many people there have rotora rotors I figured I would put it here too. anyways here is a straight copy-paste from my other post:
ok, so just in case none of you saw my other thread i'll give a refresher. I installed some new rotora rotors on my 3.0 and have attempted to do the break in procedure exactly as it is written in the rotora. Either way as soon as I put them on I was very gentle with the brakes. About 120 miles into the break in i had to drive to school which involved the highway and I noticed that when I used the brakes on the highway even lightly that the steering wheel would shake like crazy.
has anyone ever run into warped rotora rotors from teh factory? I only have about 300 miles on the rotors and pads on the front and am trying to get themm replaced under warrenty sine they seem to be warped. this sound about right to you all?
i really doubt that your rotors are warped...maybe you should re-torque the lugs? Also maybe when you took of the tires a balance got moved around. Also what new brake pads did u install?
1 Post
already double checked on the lugs, one of the studs was stripped so I had it replaced and had the wheel weights checked out and all the balancing checked out when it was replaced. all looks good, and is only noticable during braking, and not during normal driving.
I have some axxis/pbr organic pads on because I didn't want squeeling with the metal masters. someone told me I should have ceramic pads on there. does that sound right?
1 Post
bummer, so Im not alone at least. were you abole to get them replaced under warrenty? did you install them or did you ahve a shop install them and if you did have them replaced under warranty, what did you have to do to get that?
1 Post
yep, broke it in perfectly, but i had to drive to school on the highway after about 100 miles on the rotors, and I was going about 80 for the first time since putting on the front rotors and lightly pressed the brakes and the whole car shook like crazy. They are slotted by the way.
I just took them off and put on the stock rotors again since thy were in relatively god condition and the shaking completely vanished, so it must be the rotors.
and I know that slotted rotors will make a little shaking, but the shaking was so bad the rear view mirror got moved to point a different direction and I had to adjust it again.
I'm gonna try to get them replaced under warranty because it must be the rotors since the problem completely disappeared when I switched out just the rotors for the stock ones.
Your concerns:
Any time a rotors structure is compromised through cross-drilling or slotting the rate of warpage is increased... if the bit used to make the slots/drillings is dull it will cause excess heat and the rotor will warp during the process.. it is not present to the naked eye.
If the rotors are drilled/slotted (heated up) then not stored properly = they will warp.
If the rotors are NOT stored properly overtime (laying flat) they will warp.
The rotors can be installed either way but i suggest you make sure you installed as the manufacture prescribed.
good deal.. atleast you were smart enough to remove them and get them replaced.
I prescribe you do not get slotted rotors since you troubles the first time around.
I also prescribe that you do not run Ceramic pads..
1 Post
lol, what are you the brake doctor?
well the thing is, that they were made to order (ie. they made them AFTER I placed the order), and I put them on 2 weeks after I got them. They were sitting flat in a box the whole time before i put them on.
why not use ceramic pads? the rotors are performance rotors and are meant to withstand the harsher pads. I think I will just get some solid rotor replacements if i can.
Originally Posted by berny
i have 7000k on them and they are warped. These rotors suck
Originally Posted by dukmahsik
yep mined warped after a few hundred miles as well
Blown is Best
The rotors on our TL-P are slightly warped and they are cross drilled and slotted. No problems on the BBK on the CL-S so I think the problem is only isolated to the stock sized replacements. I too did a good bedding in process on the rotors and pads. I'll probably try cryogenic powerslots next time.
Former Sponsor
There are a few instructions that ROTORA puts in when installing these rotors. Firstly, you need to wash the rotor clean with soap and water. Secondly, you need to torque the lug nuts at the correct ft/lbs of tq and also in a star pattern. Thirdly, you need to take it easy on the brakes for at least 250 miles.
Saying that, did you drive through any puddles after some spirited braking and get the rotor wet after it had heated up significantly? Did you do the proper break-in procedure immediately after the install? (Speed up to 60mph and gradually slow down to 10mph without stopping if at all possible six to ten times immediately after installing the rotors) Also did you install these yourself?
Josh
Excelerate LLC
Josh
Excelerate LLC
Blown is Best
Josh
Excelerate LLC
Josh
Excelerate LLC
These cars were engineered to use semi-metallic brake pads NOT organic. Organic pads are not designed for the higher temps that all vehicles are creating today. I do not know of any vehicle produced today that comes from the factory with organic pads. You will see organics for the rear because they do a much lower percentage of the braking. After braking, as the brake cools down, the organic pads are "leaving behind" friction material on the surface of the rotor. This causes a uneven rotor surface so the next time you brake you feel the vibration. Have your rotors turned and get a good set of semi-metallic pads. It is more important to "break in" the pads then the rotors. It is equally important that the hub and wheel flange are flat and in good condition and that the wheel bolts or hat mounting hardware is in good condition, installed correctly and tightened uniformly and in the correct order to the recommended torque specification.
Good luck as my 01 CL-S is having the same issue as I research which friction material to try next.
1 Post
funny because I called the rotora phone number and asked the guy that specific question about using organic pads and he said that would definitely not be the problem. I might have overtightened the lugs, but I didn't really tighten them THAT tight. I am 6' tall and 135 lbs, with absolutely no fat on me. I don't have much power to put into the tightening.
If you trorque them down above 80:
1. you will damage the hat and cause the rotor to warp.
2. you will do what you did already and strip the lug out.
I am actually about 3 steps below a Doctor...
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
RSpyder
09-30-2015 12:46 AM
