brake questions
Old Apr 18, 2005 | 12:59 AM
andyjl's Avatar
brake questions
What are the differences between the regular Rotoras vs the BBKs?
Old Apr 18, 2005 | 07:59 AM
RaviNJCLs's Avatar
The biggest difference is that the regular Rotoras work are just replacement rotors. They work with the stock calipars. The BBK replaces the calipars with a 4 piston calipar. This will make the stopping power of the car much better.
Also, the stock rotors are smaller than the ones available with the BBK. I think the ones available with the BBK has a 13 inch diameter. Stock rotors are a little less than 12 inches. The regular Rotoras are the same size as the stock ones. These are also just slotted and the one with the BBK are slotted and cross-drilled.
Save the cash and get the BBK. That's my plan.
Old Apr 18, 2005 | 02:29 PM
andyjl's Avatar
i don't have the money to get BBK. So i was just gonna go with the regular rotaras. But how much better are the regular rotoras compared to the stock ones? is it worth getting to replace the stock ones or is the upgrade to rotoras just give you a little bit better braking?
Old Apr 18, 2005 | 10:37 PM
Chopsie's Avatar
Beware of leakage
Andy, anything is better than the stock rotors
Old Apr 19, 2005 | 01:17 AM
andyjl's Avatar
lol..of course
Old Apr 19, 2005 | 02:40 AM
Crazy Bimmer's Avatar
BBK are a waste unless you track your car. IMO
Just get better pads, SS lines, new brake fluid and you should be good to go.
Rotora rotors would be a good idea also since the stock CLS rotors warp easy.
Old Apr 19, 2005 | 09:42 AM
NiteQwill's Avatar
Adventurist.
Drive the a stock CL-S then a BBK equipped CL-S... You would change your mind immediately. The stock braking system SUCKS, the best mod I've ever had on this car is upgrading the silly stock brake system.
Old Apr 19, 2005 | 12:32 PM
Well i have driven a stock TLS for over a year. My guess is your stopping increased from the new pads, lines, and new fluid from that BBK.
Old Apr 19, 2005 | 02:34 PM
NiteQwill's Avatar
Adventurist.
No, they increase because of the addition of 3 more pistons. Pads, lines and fluid are minimal in change with regards to braking power.
Old Apr 19, 2005 | 02:35 PM
RaviNJCLs's Avatar
I can't wait to get mine.
Old Apr 19, 2005 | 08:12 PM
Time For Sleeep's Avatar
That's Racist
A full BBK system costs like, a G right?
Old Apr 19, 2005 | 08:17 PM
andyjl's Avatar
they cost a lot more
Old Apr 19, 2005 | 08:20 PM
Allout's Avatar
Blown is Best
The difference between the two is drastic. Tracking the car is not the criteria to buy these. In my opinion, there's no need to drive fast if you can't stop fast. BBK will give you the ability to do multiple stops or braking. You will have greater confidence in your brakes in the hills and high speed in the flats.
mada51589
Jan 9, 2025 04:40 PM
pstomps
Feb 20, 2017 03:29 AM
datadr
Sep 12, 2015 09:12 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
