brake questions
The biggest difference is that the regular Rotoras work are just replacement rotors. They work with the stock calipars. The BBK replaces the calipars with a 4 piston calipar. This will make the stopping power of the car much better.
Also, the stock rotors are smaller than the ones available with the BBK. I think the ones available with the BBK has a 13 inch diameter. Stock rotors are a little less than 12 inches. The regular Rotoras are the same size as the stock ones. These are also just slotted and the one with the BBK are slotted and cross-drilled.
Save the cash and get the BBK. That's my plan.
BBK are a waste unless you track your car. IMO
Just get better pads, SS lines, new brake fluid and you should be good to go.
Rotora rotors would be a good idea also since the stock CLS rotors warp easy.
Adventurist.
Adventurist.
Well i have driven a stock TLS for over a year. My guess is your stopping increased from the new pads, lines, and new fluid from that BBK.
That's Racist
Originally Posted by NiteQwill
Drive the a stock CL-S then a BBK equipped CL-S... You would change your mind immediately. The stock braking system SUCKS, the best mod I've ever had on this car is upgrading the silly stock brake system.
Blown is Best
mada51589
05-03-2022 08:54 PM
