Brake Pedal Goes to the Floor
Old Oct 10, 2011 | 07:22 AM
nbennettksu's Avatar
i heart latin chicks
Driving Saturday night and hit the brakes, pedal felt soft... hit the brakes again and pedal went all the way to the floor. If I pump the pedal a coulpe times it gives me a little resistance and then the pressure goes away again. pedal also gets stiff when vehicle is shut off. Res is full of fluid; I think its the master cylinder, but I'm not 100% sure. I tried searching to see if there has been anyone with common issues and really couldnt find anything. I have about 130k on the car; I'll get it looked at--at work today.
Thoughts?
Old Oct 10, 2011 | 07:27 AM
Brake master cylinder
Old Oct 10, 2011 | 08:36 AM
ThomWV's Avatar
Master of Mountain roads
You have a serious problem. Somewhere in your brake system that has been a failure of either a brake line, a fitting, or a seal. It has to be one of those things. First, a brake line may have broken. This will cause an instant loss of fluid when you hit the brake pedal and no pressure at the caliper the line leads to. Fortunately because of some interesting plumbing and such you should not lose your brakes completely when the line breaks, not immediately that is. You may get a few stoops out of the car, but that will be it. The next thing that could be wrong, but almost never is the problem, is that a fitting may have failed - not likely but possible. The effect would be the same as a brake line breaking. The last possibility is that a seal has failed. This is not an uncommon failure at all and its certainly not limited to Acuras. There are seals in the Master Cylinder and in the individual break calipers. There will be fluid loss from failed seals too, but sometimes they lost fluid isn't obvious. In any event the three different things have the same effect when failure takes place. In every case it becomes impossible to pressurize the system and without that pressurization you have no brakes.
Whoops, maybe I should have said this first. This is, at the most basic level, how the system works.
First you press the brake pedal. The pedal is connected via mechanical linkage to the master cylinder. The pressure from your foot is relayed to a rod in the master cylinder that pushes on a piston. The piston has a seal so that pressure is not lost as the piston pushes against the brake fluid contained in the cylinder. The fluid then travels through the lines and fitting to the calipers. If there is a break anywhere in the lines or fitting the pressure will be lost. Finally the lines enter the calipers and there it pushes agains the caliper pistons - each of which also has its own seal. If that caliper seal fails the pressure and fluid will be lost without moving the piston. That piston, but the way, presses directly against the brake pad and moves it into the caliper to effect braking on a working system.
Old Oct 10, 2011 | 09:04 AM
Excelerate's Avatar
Former Sponsor
It's definitely a hydraulic leak and most likely the master cylinder. Look in under the dash and see if the master cylinder is leaking inside the car.
Old Oct 12, 2011 | 10:20 AM
Josh, its not leaking into the car...
Old Oct 12, 2011 | 10:28 AM
fuzzy02CLS's Avatar
If the fluid is not going down nothing is leaking. But air is coming into the system. Sounds like a bad booster/master to me. I had a few fail on Fords & that is what happen. Pedal to the floor no stopping but fluid was full.
Old Oct 12, 2011 | 10:30 AM
read my thread about a failing MC.
https://acurazine.com/forums/showthread.php?p=12765078
Old Oct 12, 2011 | 01:35 PM
SG81's Avatar
Missing My CL-S
this happened to me last weekend. at first i thought it was the caliper seals gone bad but after checking it out it was my brake line leading into the caliper that broke. decided to replace both sides and ordered new brake lines today and gonna go pick them up tomorrow
Old Oct 12, 2011 | 05:57 PM
aznboi2424's Avatar
Stainless steel lines I hope.
Old Oct 13, 2011 | 09:00 AM
SG81's Avatar
Missing My CL-S
the one that broke was a stainless steel line. i orderered OEM ones since i don't really care about upgrading anything on this car anymore. as long as it gets me to work and back, that's all i need
Old Oct 13, 2011 | 01:48 PM
civicdrivr's Avatar
What lines were you running?
Old Oct 13, 2011 | 02:46 PM
1sickaccord's Avatar
just like everybody else mentioned already check your brake lines first, if no leaks or rust then it's your master brake cylinder, pretty easy fix
Old Oct 13, 2011 | 04:33 PM
aznboi2424's Avatar
Would like to know what lines too as I plan to buy SS lines in the future
Old Oct 13, 2011 | 04:44 PM
^head to excelerate
Old Oct 13, 2011 | 04:51 PM
SG81's Avatar
Missing My CL-S
they were Russell lines that were on the car for about 5 years. it was the drivers side that got frail and disconnected. put in the new lines today with new rotors/pads and it's like new again
Old Oct 13, 2011 | 06:10 PM
civicdrivr's Avatar
Interesting. I think Im running Russell lines. Ill have to keep an eye on them.
Old Oct 14, 2011 | 10:07 AM
Excelerate's Avatar
Former Sponsor
http://store.excelerateperformance.c.../i-251977.aspx
Old Oct 15, 2011 | 08:06 AM
It was my SS brake line that was leaking. I ordered the Wilwood BBK a few years ago and the brake lines were a little bit too long... well, the brake line ended up resting on the CV boot and rubbing thru the brake line.
Old Oct 15, 2011 | 08:21 AM
Since the BBK does not accept a banjo bolt, I had to get a line custom made (since the Cl is my only mode of transportation), I could not wait for one to be shipped to me.
Old Oct 15, 2011 | 09:28 AM
glad you found your leak.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
JDM96specCTR
Oct 17, 2015 01:06 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
