Brake pads, any upgraded yet?
Old Jul 26, 2001 | 12:24 AM
davo-cls's Avatar
aka davo-tsx
O.K. so a Brembo kit requires larger wheels and a bigger offset, not to mention costing over a grand just for the Brembos - has anyone replaced the pads with something like Metal Masters that Comptech sells?
Old Jul 26, 2001 | 12:43 AM
blazerbob1's Avatar
With only 4000m. I haven't replaced pads yet,
but you can believe I will replace with hi-perf. pads when they need replacing! Will be installing Neuspeed Teflon Coated Stainless Steel Brakelines within few days.
Old Jul 26, 2001 | 05:18 AM
Water Rabbit's Avatar
Wow only on my 2nd tranny
Yes, I upgraded to Porterfields (R4S carbon/kevlar)at the same time that I switched to vented rotors, steel braided brakelines and ATE Super blue brake fluid. it's hard to say witch components make the most difference, but altogether the brake feel is better and more confidence inspiring.
Old Jul 26, 2001 | 11:17 AM
Al Uminum's Avatar
Originally posted by Water Rabbit:
<STRONG>Yes, I upgraded to Porterfields (R4S carbon/kevlar)at the same time that I switched to vented rotors, steel braided brakelines and ATE Super blue brake fluid. it's hard to say witch components make the most difference, but altogether the brake feel is better and more confidence inspiring.</STRONG>
Water Rabbit: Them pads are supposed to be very good. Did you get the Porterfields at a shop or did you order them somewhere. If you ordered can you reveal your source? If your mechanic ordered them for you would you be able get that from him if necessary. Sorry for being such a PITA.
Rob
SidhuSaaB
May 30, 2020 12:40 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
TL14
Sep 24, 2015 04:37 PM
