Brake light stays on sometimes
Old Apr 28, 2005 | 01:34 PM
Count Dracura's Avatar
Corpretty
Every now and then (completely randomly and intermitantly) the e-brake light stays on when i start the car. I never use the e-brake except on hills.
Then it will do strange things like go off when i press the regular foot brake, but come back on when i hit the gas again. On off, on off with no pattern i can see.
Any ideas? There doesn't seem to be anything wrong with the car but i don't have an owners manual so i don't know if that light can imply more than just the e-brake being engaged.
Thanks!
Old Apr 28, 2005 | 02:54 PM
cltypeSLOW's Avatar
Don't Mess With Texas
check your fluid...
mine does that when its below 45 degrees for some reason..then after the car warms up it quits
Old Apr 28, 2005 | 02:56 PM
Slimey's Avatar
Where is my super sauce?
The brake light can light up with any malfunction with the brake system. As said above, check your fluids.
Old Apr 29, 2005 | 04:39 AM
rtatsutani's Avatar
Never had a clean run
Yep, it's most likely your float gauge for your brake fluid. It gets sticky every once in a while and needs to be moved around. It's a little messy, but gets the job done
Old Apr 29, 2005 | 11:22 AM
Corpretty
Thanks for the info guys, i'll check the brake fluid and float guage asap.
Old Apr 29, 2005 | 02:39 PM
Dan's Avatar
Dan
Confused
Some early models had sensors go bad in the brake fluid cap.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
PortlandRL
Sep 14, 2015 12:01 PM
Birdflunuggetz
ILX
Sep 14, 2015 07:00 AM
