Brake Lamp ON
dont be mad
Brake Lamp ON
so the "Brake Lamp" is lit up on my dash, looked in the manual and it says that this means one of your brake lights are out....but all of mine are fine. Is there anyway to reset this light?
dont be mad
thanks
AcuredCLS
ehhh i hope your not bringing your car to jiffy lube
"Clean exterior windows
Vacuum interior floors
Check tire pressure
Check and top off the following fluids:
-transmission/transaxle fluid
-differential fluid
-power steering fluid
-windshield washer fluid
-battery water (excluding sealed batteries)"
can be found at http://www.jiffylube.com/specialprom...romotions.aspx
If your "BRAKE LAMP" indicator is on, just try and unplug and replug them. But if your "Parking BRAKE" indicator is on, then that is when the topping off of fluid will help.....teh lil float gets stuck sometimes!
i want a lip..
haha... jiffylube... worked there for a year, my store was super scandalous.
brake light... mine did the same thing, the problem for mine was that the little 'buoy' attached underneath the brake reservoir cap was clogging up, so all i did was got a screw driver and wedeged it out... slid it up and down a few times... and light never came on again. a mechanic at a local shop said that the 'buoy' thing was a sensor that checks the brake fluid, and my 'buoy' was getting stuck towards the bottom of the reservoir, telling the computer that my fluid was low.
ThegreatGATHby (10-20-2011)
dont be mad
i didnt go to a jiffy lube it was a smaller oil changing shop where they do emissions tests too, but i actually checked my lights again the other day and one of them was out but i swear the 3 times i checked before that no lights were out. oh well easy fix the brake lamp is off now
GWEEDOspeedo
01-15-2016 10:39 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Eggs999bacon
09-24-2015 10:08 AM
