Brake Fluid Change
Old Apr 4, 2003 | 09:20 AM
elliot's Avatar
It's Always Shabbat
Brake Fluid Change
It's been about three years now since the car was purchased, so I guess it's time to change my brake fluid? Do you guys follow the book and change it at 3 years?
Just checking.. Thanks
Old Apr 4, 2003 | 10:25 AM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
I will do it at 60 kmiles.
Old Apr 4, 2003 | 10:26 AM
tdtsai's Avatar
I did mine recently. You will need an equipment made for that purpose. It's like a vacuum pump, similar to the top side oil pump, to draw the brake fluid at the calipers. One person can do it. Best to power jack to raise the car to save time
Old Apr 4, 2003 | 11:15 AM
GreenMonster's Avatar
I need to change the brake fluid on my bus soon, so I've done some research on power bleeders.
Here the one I'm planning on buying:
http://www.motiveproducts.com/index.htm
and here's a webpage to make your own from a small garden spayer, some tubing and a couple compression fittings:
http://www.bmw-m.net/TechProc/bleeder.htm
Old Apr 4, 2003 | 05:52 PM
dfreder371's Avatar
Be careful here, brake fluid is INSTANT DEATH to paint! Do not get some on your fingers, and touch the body. anywhere.
Curious though, about the power brake bleeding systems here. Doesn't it seem counter intuitive to try to power air down in a system, when it wants to rise? On airplanes, we just replace the bleeder nipple with a new one ($2 each, so we know it is clean), and pump the fluid in from the caliper, forcing the entrapped air up. Doesn't that make a lot of sense?
Old Apr 4, 2003 | 10:29 PM
elliot's Avatar
It's Always Shabbat
So should I wait until 60k or so to get my brake fluid changed? What about my transmission fluid? I'm at 38k miles on a 2001.
mada51589
Jan 9, 2025 04:40 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
ulrblitzer
Sep 24, 2015 07:42 PM
cacheflowe
Sep 14, 2015 10:35 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
