Brake Clarification
Skillionare
Brake Clarification
Sorry Guys,
I did a few searches before posting. A while back I remember reading about replacing out our stock calipers for rebuilt Legend or NSX ones. The reason for this was it was a quick swap/upgrade to dual piston calipers vs our single piston ones. I am ordering some slotted rotors and was just curious. I tried to search for the thread again but to no avail.....any advice anyone has would be great. Thanks in advance.
Not Asian
Skillionare
Originally Posted by gaping46and2
Order the CL ones, they'll work just fine with the Legend/NSX calipers...I'll be doing this next week.
Skillionare
Gonna roll with a set of these:
http://www.wholesaledirectparts.com/...5-153-96-56-32
Any reason you when with these instead of Rotoras? Those are the ones I would recommend. And EBC pads. That's what I had on my CL when I made the NSX caliper swap.
Skillionare
Originally Posted by RaviNJCLs
CL rotors and pads will be what you need.
Same quality but cheaper. So these will work with NSX/Legend calipers then? They are to original Specs.
Originally Posted by phipark
damn, sorry...I just did a search for calipers.
Skillionare
They should work if they are standard CL rotors and pads. I cannot say for sure since I've never seen them before. I know that the Rotoras work since those are what I had.
WOW, I had no idea this was even possible.
Those that have done this, what are your thoughts on it, do you like it, are the improved braking gains noticeable and/or worth it?
Does anyone have the part numbers for the Legend and NSX calipers that are compatible with the CL-S?
This would be an awesome mod rather than going full out and having to buy the brembo or other big brake kits and still have improved braking.
OH Oh found a nifty thread on the NSX caliper swap:
https://acurazine.com/forums/showthread.php?t=115693
If I remember correctly, the ones that fit from the NSX were the ones on the 1997 and earlier NSX.
The Legend ones are a bit better. The pistons are bigger. Remember with the Legend calipers, you have to swap sides. The Left caliper go on the right and vice versa. The NSX ones are a direct swap.
Ravi, what about the rear calipers ? Can those be upgraded to 2 pistons too ?? I know Mr. Steve post pics showing 4 calipers in the "NSX caliper" thread that Sly linked... Guess I could PM Steve...
I've added a couple of links to the info thread on this topic... if anyone thinks of some more that should be added, post 'em up here:
https://acurazine.com/forums/showthr...&goto=lastpost
Greenie, I don't think the rears will fit.
Based on the reading I did you would have to do way too much to get them to fit. I also asked one of the Acura techs that worked on my CL when it was at the dealership. He said he didn't think they would fit either. This was after he saw my fronts and did some searching on his own.
Also, based on the diagram below, the rears are a single piston caliper.
![](http://www.acuraoemparts.com/delray/jsp/catimgs/13sl00_b1910.gif)
For the CL....
![](http://www.acuraoemparts.com/delray/jsp/catimgs/13s3m0_b1910.gif)
Seems like a hell of a lot of difference to me.
For the CL....
Here's a question for ya Ravi and those that have done the swap.
Is the changed brake balance a concern? Obviously the front is going to be a lot stronger than the rear, in hard braking conditions does that pose a problem?
Skillionare
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
