bought a j32
bought a j32
Finally found and bought a 76000 mile j32a2 out of a 03 tls.
Only thing is it was an auto car. I will be putting it in my 6 speed cl. I found a small list to make it a true 6 speed. Yall let me know if I'm missing anything!
Front cam pulley 14260-PGE-A11
Front plate assembly (behind cam pulley) 11860-PGE-A10
Timing belt pulley(lower) 13621-PGE-A11
Crank shaft sensor 37500-PGE-A11 (this little sh!t costs $500.00)
Subharness for CKP 37501-PGE-A10
TDC Sensors (Qty 2) 37840-PGE-A11
TDC SUB HARNESS 37841-PGE-A10
Unregistered Member
I went from manual to auto, and you have everything I changed except one thing.
The auto uses an ECT sensor or something kind of behind the cam pulley. When converting to manual, you will remove than sensor because the manual doesn't use that.
This will leave a hole which will leak coolant I think. The manual engines have a cap that threads into the hole with a giant hex socket (size 26 or something).
If you have your old engine, you can swap the cap. Or you might be able to just cut the wire harness. Or I can send you the one from my manual engine.
AcuraCls6speed (04-02-2015)
I am not buying them new I am swapping them over from my old one. I don't think I said anywhere that I was buying new. Not doing the j35 because I found this one for a cheap. My engine now is in bad shape because it got over revved bad. It runs like ass. Just making the car reliable again not trying to soup it up or anything.
I have a question, do you guys think I can remove the engine from the top?
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
dainmezron
10-16-2015 06:56 PM
