Body Roll?
Old Aug 12, 2002 | 09:07 AM
i81monkey's Avatar
Body Roll?
Can someone please explain what is the cause of body roll on the car? Is it the weight, springs, sway bar? If it is the sway bar why would Acura not install larger sway bars to begin with? Do some people like body roll in automobiles? Also how is the structural rigidity of the CL body? Sorry for the array of questions. Thanks in Advance
Old Aug 12, 2002 | 09:16 AM
juniorbean's Avatar
Almost all cars come with some form of body roll. To reduce the body roll, you will need to lower the car with aftermarket springs, and tighten it up with aftermarket sways. The reason it doesn't come from the factory like that is b/c it gives a rougher ride. Acura is a luxury car company, so on any model above the RSX you can almost guarantee that they are not going to sell their cars with a rough ride. It comes from the factory with a balance of handling and comfort. Then, if you want to alter the ride and performance yourself, you can modify the car.....
Old Aug 12, 2002 | 01:41 PM
Kkranghkar's Avatar
Grammar Police
For more info than you ever wanted about swaybars and body roll, see:
http://www.grassrootsmotorsports.com/swaybars.html
The main point is that there is always a tradeoff... There is a reason cars have independent suspensions for "body roll", and that is to ease up the forces acting on the tires.
If you get super-stiff sways and have bad rubber, it doesn't do you any good.
Old Aug 12, 2002 | 02:25 PM
someguy's Avatar
Body roll stems from weight transfer. The only way to reduce it is, as juniorbean said, to stiffen up and shorten the springs and anti-roll bars. Also, reducing overall weight helps...
You are never going to get rid of it though...
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
