On Board Diagnostics 2 Port
I am trying to locate the On Board Diagnostic (OBD II)port for the CLs. I'd like to hook up a laptop to the car so I can get some running numbers off of it.
Anyone know where its located?
I've got a co-worker buddy who bought his software from http://obd-2.com/ for his WRX.
He wrecked his WRX about 2 weeks ago(totaled) and took out his mini linux box, and his 5.6 inch LCD screen. I haven't tried to hook it up yet, but we're going to try tomorrow at lunch and see if it works OK or not. If it does, then I'll probably buy all the stuff from him.
I'll let ya know how it goes.
Originally posted by scalbert
Yea, definitely let me know how it works and what parameters are available. That is the best prie I have seen on this type of system.
Originally posted by CO-CL-S
Actually $162 for Triple Combo to cover all cars sounds pretty reasonable?
If I can get the hookup from my buddy, then I won't need to look any further. He says this is about the cheapest he could find that would work for his ride. If it works for us also, then I would think this is a pretty good buy. I'll find out in about 3 hours.My vague 2 cents...:P
Damn... you must get a long lunch!
It will be a piss poor install just to see if we can get it working. He don't expect it to take more than 15 mins just to see if we can get a reading. He already has the AC/DC conversion thingy (don't know what the hell its called) and says its a cinch to hook up.
I meant this http://www.obd2.com/win_ce/data/win_ce_pricing.htm
for my Sharp Mobilion Win CE Pad....
Originally posted by fbazakos
it's an inverter ... i have a bunch of them ... can you please take pics?
Yep, the OBDII port is below and behind the Coin Holder/Ash Tray. You just hook up to it with the provided cable and software and monitor various engine parameters.
How many parameters are available is what I'm interested in?? Also, I didn't see anything about reseting DTCs, just reading them. It is great to be able to reset the codes...
We currently have no mods to tune for or with (except for those with V-AFC). But if you are going to wrench on your own vehicle the tool is invaluable.
The ability to see what the engine is doing is also inetresting. But as the aftermarket increases the need for seeing what is occuring is paramount. I can't see how people would ever significantly adjust their fuel pressure without watching fuel trim values but some do.
You can see things from MPH, RPM, System Voltage, etc. But then you can also watch the afore mentioned fuel trim values, add to that the knock counts (detonation), ignition timing and knock retard, MAP, MAT, Calculated Load, etc. There are many values to allow you to see the 'health' of your drivetrain.
It worked... It was a lot easier to use the laptop vs going the inverter / LCD / mini linux box route we initially planned. The laptop we were using had NO juice, it went dead in like 4 mins after we unhooked it from the power supply. As soon as I tried to get a screenshot it went dead. I did however manage to get some numbers off of the car.
True, enough, you can't write to the ECU, but then again, this is a "diagnostics" port, not a "hey I wanna write some shit to my ECU so I can be cool" port. IMO its just something fun to do.
Once the laptop gets a bit more power, we'll go back out there... Screenshots, and pissy digicam pics soon to come...
There is no need to write data, none of the similar tools can. But can it reset trouble codes?? If you can find out that would be great. But regardless, I have email them with the same question.
So in short, yes, it can.
It was a rush post so I didn't get to put explainations of what the hell was going on in the pics... but never the less, here are 28 crude digicam shots. Most are of the RPMs and load ratings, and some of fuel pressure. I tried to take a sequence shot of the graphs so you could kinda see how it updates. Roughly 7-9 frames per second depending on how much data you are querying, the more data you ask for, the less often it updates (obvious).
Click the image for a larger picture
http://www.thefiresauce.com/Mantis/acura.htm
I also took a pic of the LCD, for the final install, I'll have to figure out where I'm going to place it.
Mantis
Mantis
Well it looks like our server is being shit and doesn't want to dish out the larger pics, I'll fix it tomorrow. But right now I've gotta get the hell away from work. (which is where all the pics are)
Here are a few links you might want to look into also
http://www.netech.dk/pda/indexe.html
http://www.aeswave.com/Palm/CJ2/
http://www.auterraweb.com/scantools.html <- Nice
Their not quite Honda PGM-F1 scanners but they do all the generic OBDII registers and a few 9141-2 and nonuniform honda dtc's...
Its a starting point .. most range from 150-400 .. some get upwards of 1K depending on what apps your looking for (GM/FORD/BMW/Honda/Etc).....
Hope that helps some
I do like those and it would be a choice if I had a Palm/Visor or a WinCE handheld. But I have historically used my laptop for this, and probably will continue since it is basically with me at all times. Oh yea, and free to me...
But thanks for the info...
Well Excuuuusssseeeee ME ! LOL I use my laptop for most everything too, just for storage and trending analysis .. but the Palm (if you already had one) is great for roadside/track quick peeks
Originally posted by Davediego
What kind of cable does it connect with?
Yea sorry thats what I meant, how much does that OBD II connector cable cost and where do you get it?
Ohh, and the larger pics are fixed on the server. Still running slooooow though.
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
