Blown Rear speakers ...AUDOFILES HELP
fellow MASShole
had my components and amp installed the other day ... heard rattling in the back .. took off rear speaker covers and found that my infinity's are all cracked up ... WHAT DO I DO ??
1. by expensive rears
2. cheap ones ...
cause i heard somethin about rears just being fillers??? need some audofile advice thanks
MaCe
2. cheap ones ...
MaCe
I don’t see a Subwoofer listed in your signature.
It sounds like you put too much LOW end power into the 6X9’s.
Get a Sub (or two) and put a crossover on the replacement 6X9’s to block some of the BASS and you shouldn’t have the problem again.
Shawn S
Shawn S
fellow MASShole
Originally posted by amirsafdari
audiofiles? u want my mp3's to help u out? wtf
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
when u talk about low end... could i just adjust the gain on the amp ... srry for the noob questions car audio isnt my thing
MaCe
My $.02
Originally posted by MaCe
ohhh whatever the term is..... no whoring needed!!!!
:sqnteek:
MaCe
MaCe
I would advise a couple of things to get the most out of it (it will cost more in the beginning, but will save you serious money in the long run since speakers even cheap ones, if they need to constantly be replaced will get seriously expensive).
-Get a sub, and like posted previously filter out the low end to the sub, and away from the 6x9's.
-When you do get the replacement 6 x 9's I would replace with what you have up front (try to keep the components the same). The rear is basically for rear fill only, but this assumes that you have a sub to cover the low end of the frequency spectrum. So I would still suggest getting a sub (not a very big one, say an 8 or so) if you want to go the low end option, but if you don't want to do that, the next step is to get some 6 x 9's that can somewhat cover the low end for you.
fellow MASShole
yea the subs WERE on the way in a couple months ... who knows now... think i'll might go the cross over and new 6x9 route for now i am low on cash so im not ever sure that can happen ... i'll put a link to this in the audio forum but any more help is much appreciated thks
MaCe
MaCe
Example:
If you cross the 6X9’s at 80-100 Hz, frequencies below that will be blocked and sent to the Sub.
Without a Sub, you won’t hear the LOW BASS notes at all.
Shawn S
fellow MASShole
Originally posted by Shawn S
If you go with crossovers, you NEED a Sub otherwise you’ll be missing the lower frequencies.
Example:
Shawn S
Example:
Shawn S
MaCe
... so basically i gotta suck it up and by the whole thing eh ???
100-Watts full range into a 6X9 is asking for trouble.
Shawn S
akbears15
15
11-05-2015 07:06 AM
Pegon95
09-15-2015 01:54 PM
