Best Way To Debadge???
The Screeching Toyo's
Re: Best Way To Debadge???
Originally posted by maevonee
whats the best way to debadge the car that glue is really stuck on there!
If you just got it, let it sit in the sun for a good 4 hours!! At the hottest part of day. Like 11AM to 3PM. Make sure the trunk is facing the sun the whole time. Then take some dental floss or some fishing line and go to work. If it is hot enough, the 3.2 CL part will come off in your hand with VERY LITTLE effort. The A-C-U-R-A will take a little more effort. If it is hot enough, slip the line between the paint and the glue and slide it through. It should come right off. If it leaves some residue behind, take some cleaner to it. Then wax and BOOOYA!!!!!!!
i didn't even use fishing line. i let it sit in the sun till it was good and hot, then i just pulled them off w/ my fingers. didn't leave any sticky stuff behind. next i used buffing compound to remove any evidence, then wax.
If you don't want to bake your car, just pour some warm/hot water over the area. I did mine the 2nd day I had it and the same time I was washing/waxing it anway. Used some floss underneath just for good measure.
Originally posted by peiqinglong
Use some Goo Gone to wipe off any extra residue.
Originally posted by Seattle Cl-S
Which, if any, of the logos on the trunk have drill holes?
The A-C-U-R-A and the 3.2 CL and the Type S are all just stuck on.
Here is a pic of my baby. I took off everything that I could without having to do any kind of body work!!!
Originally posted by AztecRol
The "A" that has the ring around it, has two pegs that mount into the trunk.
Wasn't for you!!!!!!:pfawk: :pfawk: :pfawk: :pfawk:
It was for Seattle Cl-S and maevonee!!!!!!
But I still you!!!!!!!
TLDude876
12-28-2016 03:18 PM
