best cooling mods for performance
Hey guys, quick question. What are the best cooling mods out there for the CL auto not the 6spd. I know the thermoblock spacer kit is good, the spoon or mugen thermostat is also good, but how about the fan switch? Does the CL type-s auto have three fan switches controlling the fan or just one? If its just one will the prelude fan switch fit? If its three where do I purchase the fan switches? Any other cooling mods? Maybe a throttle body bypass or something? Let me know folks. thanks for the help
mugen mods: fan switch, thermostat, radiator cap
coolant: 100% distilled water with one full bottle of water wetter
thermoblok: selfexplanatory (comes with a throttle bypass)
JetHot coating on headers
I have all of the above and you can definitely tell a difference between night & day in terms of engine heat produced
how does the radiator cap help?
Okay I understand the distilled water, cap, TB bypass, but how about the fan switch(s)? Is there one fan switch or three? Also which thermostat is the best? The spoon or mugen thermostat? And does anyone have all these part numbers for the fan switches and thermostats?
Search
https://acurazine.com/forums/showthr...=mugen+cooling
One fan switch, not even sure if Spoon has one for us. I'm pretty sure nobody has tried it.
Running distilled water is okay weather permitting. It's 95 degrees here in SoCal
. I run water wetter also to prevent any problems. Since distilled water is 100% h2o, no minerals are presents to f* the engine. Besides, water+wetter has a higher heat capacity than any coolant out there.The radiator cap allows the system to pressurize at a certain kPSI, I believe a slightly higher one than the stock cap.
For running distilled water, I recommend shorter change intervals. Keeping it in a car too long will do more damage than good. Rust, etc.
Ok i know(as explained above) how the rad. cap works in helping the cooling prosses. I guess higher pressure helps?
BUt how does the Fan Switch help and function? Same goes for the Thermostat..
The mugen t-stat opens at a lower temp, cycling the coolant at lower temps.
Originally Posted by phipark
Fan switch turns the fans on at a certain temp.
dustin, you think running the spoon tstat would be a good idea in our area? It opens up at 65C and fully opens at 70C versus 68C/81C for the mugen. Both fan switches (mugen and spoon) operate at 80C
are u sure!!!
Originally Posted by typeR
it showed a 6-7 hp increase
are u sure, dynoed facts!!!! becos ur engine running cooler scientifically does not make more HP only as long as there is no factor contributing to heat buildup which is not the case for NA engines(lookin at the coolin or heating margin from normal operating temps), now if it were FI i had agree.................
becos of the compressed air / pressure
Beware of leakage
Originally Posted by Sun Diego CL-S
hey man, so tell me. is this gain with a combo of cooling mods together and if so, which? or is this for the t-stat alone?
Originally Posted by Chopper
He's probably talking about the T-stat, fan switch, water wetter, and thermoblock spacers.
joflewbyu2
Oct 8, 2015 11:16 AM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
