Belt sizing for the UR crank Pulley....
I hate the Mets
Here is the PDF that I believe you are talking about
http://www.unorthodoxracing.com/inst.../04060200_.pdf
Sweet as Gold
it's very easy to diy...just remove the left side engine mount (2 14mm bolys and one 17mm bolt and 1 10mm bolt...very easy) and support the engine w/ a jack. You can even raise the car on a lift w/o supporting the engine. The jack is only used to raise the engine a small amount to easily remove the side mount...after that the front and rear motor mounts do all the support.
CONTACT DEAN FOR UR PULLEY AND BELTS!!!!!
ExcelerateRep
10-14-2015 08:20 AM
