BBk & A.B.S
Old Aug 15, 2011 | 10:22 PM
cleptosis's Avatar
Talking BBk & A.B.S
JUST PICKED UP A BBK FOR 150$ AT A YARD SALE WITH AN 03 TL AND WAS WONDERING DO CAR WITH BBK OR BIGGER THAN NORMAL BREAKS HAVE BIGGER ABS UNITS AND DO YOU THINK I WOULD BENIFIT FROM A REAR BBK? THANKS
Old Aug 16, 2011 | 12:30 AM
AnthraciteTypeS's Avatar
6mt swapped..smart
Good deal, weird to find something like that at a YARD SALE?? LOL
You should be fine with the stock abs equipment as I have never seen anyone on here with a bbk (rl or other) replace or modify it.
Old Aug 16, 2011 | 06:50 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
assuming everything works that's a hell of a deal there skip..
good find
Old Aug 16, 2011 | 08:31 AM
CLSspeedx's Avatar
God nice find... I need to come to yard sales in your area! GL getting it functioning and working!
Old Aug 16, 2011 | 09:13 AM
cleptosis's Avatar
comes with 4 sets of wilwood pads does any one one if i would benifit from installing a rear stainless steel lines on my rear breaks any one use different calipers in the rear?
Old Aug 16, 2011 | 11:57 AM
brian6speed's Avatar
Lone Wolf
I believe this is the kit you have. http://www.corsportusa.com/store/cat...ducts_id=10241
It retails for7-800 so not a bad deal. Your ABS will be fine. You do not need a rear bbk. You can paint or powdercoat rear calipers red if you want. I would still upgrade rear rotors, pads and get steel lines.
Only rear bbk kit is the rotora and you really dont want that wouldnt match your fronts. Rotors pads and lines is enough.
Old Aug 16, 2011 | 11:46 PM
1foxbody's Avatar
03 CLS-6
I agree with brian6speed. That does look like the rsx kit. To know for sure measure the rotor. Here's the measurements off wilwoods site. That's the exact kit I'm going to run.
http://www.wilwood.com/BrakeKits/Bra...ept%20Type%20S
Old Aug 17, 2011 | 02:35 PM
m733l's Avatar
Originally Posted by brian6speed
i believe this is the kit you have. http://www.corsportusa.com/store/cat...ducts_id=10241
it retails for7-800 so not a bad deal. Your abs will be fine. You do not need a rear bbk. You can paint or powdercoat rear calipers red if you want. I would still upgrade rear rotors, pads and get steel lines.
+1
Old Oct 15, 2011 | 05:40 PM
cleptosis's Avatar
Does any one know how to make there fit?
Old Oct 18, 2011 | 03:01 AM
aznboi2424's Avatar
Should be just a bolt on right?
Old Oct 18, 2011 | 04:06 AM
civicdrivr's Avatar
Remove calipers, remove caliper bracket, remove rotor, install new rotor, install new caliper bracket, install new caliper, bleed system.
Thats assuming these are actually for a 2G CL/TL/6G Accord.
drillzzz
Jul 28, 2019 06:30 PM
Jul 16, 2017 07:33 AM
yesSIR-S
May 13, 2016 05:42 PM
handsom-hustla
Nov 13, 2015 05:04 PM
