BBk & A.B.S
6mt swapped..smart
Good deal, weird to find something like that at a YARD SALE?? LOL
You should be fine with the stock abs equipment as I have never seen anyone on here with a bbk (rl or other) replace or modify it.
I believe this is the kit you have. http://www.corsportusa.com/store/cat...ducts_id=10241
It retails for7-800 so not a bad deal. Your ABS will be fine. You do not need a rear bbk. You can paint or powdercoat rear calipers red if you want. I would still upgrade rear rotors, pads and get steel lines.
Only rear bbk kit is the rotora and you really dont want that wouldnt match your fronts. Rotors pads and lines is enough.
I agree with brian6speed. That does look like the rsx kit. To know for sure measure the rotor. Here's the measurements off wilwoods site. That's the exact kit I'm going to run.
http://www.wilwood.com/BrakeKits/Bra...ept%20Type%20S
i believe this is the kit you have. http://www.corsportusa.com/store/cat...ducts_id=10241
it retails for7-800 so not a bad deal. Your abs will be fine. You do not need a rear bbk. You can paint or powdercoat rear calipers red if you want. I would still upgrade rear rotors, pads and get steel lines.
Whats up with RDX owners?
Remove calipers, remove caliper bracket, remove rotor, install new rotor, install new caliper bracket, install new caliper, bleed system.
Thats assuming these are actually for a 2G CL/TL/6G Accord.
handsom-hustla
11-13-2015 05:04 PM
