bbc
Old Feb 19, 2011 | 11:43 AM
ivan06106's Avatar
bbc
wazup guys im looking to doing the big brake to my cl but i wanted to know what parts do i need if i need like a special bracket so the caliper fit,brake lines, etc lmk..
Old Feb 19, 2011 | 11:56 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
first of all it's called a bbk.. lol not bbc\
and if ur doing a bbk u need a bracket to align the new caliper to the correct position, and u should use stainless steel brake lines. new rotor and caliper are also necessary.
there is a rotora BBK in the BM section i think for 1000 brand new which is a frigging steal! get that and ur set
Old Feb 19, 2011 | 12:12 PM
ivan06106's Avatar
yeah i was doing it for my phone lolz i know is bbk...what rotors an brakes should i use
Old Feb 19, 2011 | 12:42 PM
friesm2000's Avatar
B A N N E D
Old Feb 19, 2011 | 12:46 PM
gnuts's Avatar
3.5 psi
i thought you were talking about british television...
Old Feb 19, 2011 | 12:57 PM
friesm2000's Avatar
B A N N E D
at first i did too, with the British Broadcasting Company
Old Feb 19, 2011 | 01:48 PM
ivan06106's Avatar
lmao... so were can i find the bracket to align the caliper cause i just order them acura tl calipers but i wont be putting them till i get my tl s wheels, should i used acura tl rotors an brake pads
Old Feb 19, 2011 | 02:02 PM
RoccoRock's Avatar
pretty sure you need to get the brackets custom machined if youre using TL calipers. NVA-AV6, if i remember correctly, did them for civicdrvr some time ago, but i could be wrong. Wouldve been easier to go with the Rotora caliper kit, or the wilwood kit. Russell stainless lines are a good idea; even if you stay stock.
Old Feb 19, 2011 | 02:17 PM
gnuts's Avatar
3.5 psi
RL calipers will work. NVA found out that the TL-S calipers were too hard to fit. As far as i know you can't get those on. No one makes a bracket for them
Old Feb 19, 2011 | 02:24 PM
ivan06106's Avatar
thanks guy...if i do the rotora caliper or the wildwood can i keep my oem wheels...or do i got it changed like the bracket
Old Feb 19, 2011 | 02:35 PM
gnuts's Avatar
3.5 psi
only the 04-08 TL rims will clear a BBK. CL rims need a spacer.
ExcelerateRep
Oct 14, 2015 08:20 AM
