Audio upgrade questions
Old Oct 16, 2023 | 08:06 AM
Aldebaran514's Avatar
6th Gear
Hi guys,
I am looking to upgrade my audio system for my CL-S 2001, i've read a couple of forums and watched a couple of videos but i am still not sure what to do so i fugured that you guys could help me with that maybe.
Basically i want to upgrade to a new head unit, i am leaning towards either Alpine ILX-W650 or sony XAV-AX3200 as i want android auto.
I would like to keep the rest as stock as possible so i think that either that i keep the factory amp with stock speakers and tweeters with the metra 70-1725 or that i bypass the factory amp with the metra 70-1721 but if i do, will the new headunit be able to power the stock speakers or i have no choice to have an external amp installed so that everything works properly ?
And between these two options, what would give me the best sound quality and as for the installation itself, which one would be simplier ?
Thank you guys in advanve, any suggestions or advice is welcome
Old Oct 16, 2023 | 11:43 AM
Check out and / or interact with DP01TL's thread below over in the 2G TL section, he is doing a whole new system in his TL.
This side of the forum is & that side is not much better; however, he is currently active and could give you some direction?
Onto the next project: Complete Stereo Redo... - AcuraZine - Acura Enthusiast Community
Good Luck.
Old Oct 16, 2023 | 11:54 AM
6th Gear
Good Luck.
Thanks, imma take a look for sure ! 😁
Old Nov 8, 2023 | 11:46 AM
AnthraciteCL-S's Avatar
I've been running the ILX-W650 for a little over 3 years now. I use Apple CarPlay. No issues at all. I swapped my door and deck speakers for JBL GX Series. Sounds great even with the stock amp. I need to get an amp tho.
I recommend Crutchfield when you go to purchase. Came with everything I needed to install.
Old Nov 11, 2023 | 03:11 PM
CLB1tch's Avatar
3rd Gear
if i remember correctly the stock speakers are 25w rms so they should be good to be ran off of the head unit's built in amplifier (≈18w rms). however you will have a hiss unless you use a line output converter like the scosche slc-4. if you buy your head unit from crutchfield they will usually include one for free. if you replace the door speakers go with component speakers instead of 2/3 ways with built in tweeters or else your sound will be really tin-ey
Old Mar 17, 2024 | 12:02 AM
6th Gear
It turns out that i went to a local audio shop near me and that the speaker were already been changed by the previous owner and all i add to do what to put the new head unit (i bought a pioneer that he had in stock) and it sounds really great with no hiss or any issue whatsoever. It was really easier than expected after all !
Old Mar 17, 2024 | 12:04 AM
6th Gear
yup it turns out that my speakers were already changed by the previous owner so all i had to do was to put the new headunit and it sounds really good with no issues at all. Thanks !
pretty_boy_357
Jun 22, 2010 02:21 PM
djwoody
Feb 8, 2009 07:42 PM
97AcuraCL
Aug 11, 2003 09:52 AM
MattR97
May 3, 2002 12:19 AM
crrink
Mar 18, 2001 10:06 PM
