Apexi V-afc
Apexi V-afc
Hey people, I just bought the APEXI v-tec controller. Does anybody else here have one? I didn't install mine yet because I can't find the diagram for my e.c.u. ('02 cl-s). Any 411 will be helpful and appreciated.
Re: Apexi V-afc
The diagram for the v6 accord should be similar.
spiro
spiro
I believe the diagram is available on the Apexi webiste....
if you can still return, I would get your money back, the gains you get from it, aren't worth it...unless you plan to run lots of NOS or go forced induction...IMHO...
Originally posted by Zexxy
But if you have mods on your engine you should adjust the a/f ratio.
Hi all. Just discovered this site and trying to read as many posts as I can when I saw this one. The only way to know if a S-AFC does anything is to gain HP is to take it to a dyno and put a wide-band sensor to it. Then you'll know where it runs lean or rich. If you don't have access to a wide-band then do not bother with this mod. Like Achance said, you could lose power if you don't have a wide-band.
SRCL-S
09-30-2004 11:05 AM
