Anyone know how to remove speed governor?
I was absolutely sure that our TL-S/CL-S's were "drag limited" based on the info from Acura brochures and websites. This weekend i was chasing some bikes down 95 in NJ and hit the limiter at around 148mph(it just cut off the gas on me)- WHAT GIVES?? the car felt like it still had TONS of power... i'm sure i couldve squeezed out 170, and with the new tires, 150 doesnt feel fast.
Nehow, does neone know how to remove the governor? Has neone done this on the CL/TL?
(no flames about high speeds please, if u dont like it, deal with it)
'02 Nighthawk TL-S
Comptech Springs / Comptech Headers /
Bridgestone Potenza RE730 225/45/17 on Mille Miglia Sports
Alpine CVA-1005 Head Unit / Alpine CDA-7863 CD Player / Alpine G320 EQ / Alpine DVA-5205 DVD / Alpine NVE-N851A Navi / JL Audio XR653-CS 3-Way comps for the front powered by a bridged Alpine MRV-F407 amp / Boston Acoustics 5.5 ProSeries 2-Way comps for the rear powered by Alpine MRV-1002 amp / Dual 10" JL Audio W-6 sub powered by Alpine MRV-1005 amp / Two Alpine CHA-1214 CD Changers / 20% Tint all-around
_ _ _ _ __ _ _ _ _
'00 Nighthawk TL
Aem Short Ram / Comptech Sway Bars / Comptech Springs / Cross-Drilled Rotors / Pirelli SP7000 Tires / 35% Tint all-around
Pics of my TL and Fun/Crazy Pics
'02 Nighthawk TL-S
_ _ _ _ __ _ _ _ _
'00 Nighthawk TL
<font face="Verdana, Arial" size="2">Originally posted by ZodiakTL:
</font>
</font>
Not that I will ever go that fast, I sure would like to know if you can disable the governor just for the ablitly to say my car goes 170
My friend did it with his Audi S4 and I think he said it tops out at about 170 - 180------------------
Mustang Killa
1. Unless your going down hill, I did some rough calcs, and figured out that the stock car would go around 152 or so on a level surface with no mods.
2. A car with the headers and CAI will do about 155+ (hard to know exactly) -- I just used an iterative formula and some speeds from 4th gear max and 5th gear max speeds.
So:
a. Is it really worth it for an extra 7 miles per hour (unless of course you want to go down hill).
b. The stock tires are 'V' rated for 149 MPH
If you really want to kill the limiter, there is a signal from the secondary shaft/output shaft in the transmission. Maybe the signal could be messed with... (I'm not sure about this)
I though there was a posting about a company that modified our ECU/PGM-F1 unit -- Jet or something???
Silver 2001 CL-S with NAVI
So:
- Mud guards
- Wheel locks
- Toyo T1S 235/45ZR17-97W* Proxies on 17x8" SSR Competition wheels (48lbs less than stock)
- Kevlar/SS Brake lines w/Brembos?
- Comptech headers & sways
- Silver AEM CAI
- 9 coats of Zaino magic
Mod the ECU. Cars these days are "electronically" governed, so that means it's time to mod the ECU.
-J
2001 CL-S Aegean Blue/black interior spoiler, wheel locks, no-navi
Stock for now.
[This message has been edited by JRock (edited 05-01-2001).]
-J
Stock for now.
Altering this signal Eric is referring to would probably have other side effects as well, such as gear rationality failure codes in the TCM (what gear am I in?) as the input and output shaft speed variation can no longer be measured. But in the quest for the unattainable 170MPH...who cares, go for it.
<font face="Verdana, Arial" size="2">Originally posted by syncivic:
Altering this signal Eric is referring to would probably have other side effects as well, such as gear rationality failure codes in the TCM (what gear am I in?) as the input and output shaft speed variation can no longer be measured. But in the quest for the unattainable 170MPH...who cares, go for it.</font>
What bout modifying the PCM to not upshift 1->2 ? Is that feasible?
R.I.P Integra Type-R #932
Black 2001 CL-S
Comptech Headers
<font face="Verdana, Arial" size="2">Originally posted by Crippen:
</font>
</font>
I wish we could find a hack for that. Its funny when I put it in SS and I don't even touch it till 3rd gear...
Mustang Killa
<font face="Verdana, Arial" size="2">Originally posted by WebToker:
</font>
</font>
1. Top speed -- Change the 147 value in rom to 254 MPH (just in case its a byte value)
2. The 1->2 2->1, If you can shift by using the D2->D1, I don't see why some smart person couldn't add the feature (if properly motivated).
So, who do we bug to death for the changes. Remember the squeaky wheel gets the grease!
BTW -- I don't know if Acura will be helping out with these mods.
- Mud guards
- Wheel locks
- Silver AEM CAI
where would one start looking for info on protocols and pinouts on ECU's ?
-Fiddler
ControlGenie Automation Systems
1998 Accord EX V6 Coupe (HomePage)
-Fiddler
I bet if you're friendly with a tech they could help you out.
Even byte value is good up to 255.
-J
Stock for now.
<font face="Verdana, Arial" size="2">1. Top speed -- Change the 147 value in rom to 254 MPH (just in case its a byte value)</font>
-J
Stock for now.
I just installed a Field vtec/afc in my car and it gives you the option to take out the speed limiter. Just one switch. Kinda useless to me cause I don't have a deathwish and haven't exceeded 120 mph....
1997 Acura 2.2 CL (5spd)
rubber tires, windshield wipers, headlights, horn, steering wheel, BRAKE PEDAL, clutch, brake pads, driver seat, passenger seat, back seat, front windshield, rear windshield (with defroster), lumbar support, cruise control, intermitent wiper control, sun roof (tinted), engine, pistons (only 4), emergency brake handle, trunk w/ tools, spare tire
The rabbit explodes in a puff of blood mist and fur like in that one video clip from some race where a rabbit did just that in front of an F1 car (or was it a stock car?).
As for someone switching lanes, you switch to the other one they just switched out of, and slow down, no?
Or use the shoulder if you must.
But I would think people would only go that fast if the road was deserted anyway.
-J
Stock for now.
-J
Stock for now.
<font face="Verdana, Arial" size="2">Originally posted by EricL:
The transmission had all kind off goodies controlled from by the ECU. If someone would ever get a hardware debugger/emulator on the thing, I think a lot of stuff would be possible.
</font>
</font>
yeah... when(i've only done it a few times so far) i go 150 i always make sure there is room to move around... i wont do it during rush our on the turnkpike. and i had this discussion before under different topic...
neone here have a vtec/afc controller on a 01 CL?
'02 Nighthawk TL-S
_ _ _ _ __ _ _ _ _
'00 Nighthawk TL
'02 Nighthawk TL-S
_ _ _ _ __ _ _ _ _
'00 Nighthawk TL
<font face="Verdana, Arial" size="2">Originally posted by JRock:
-J
</font>
-J
</font>
See, I get penalized for thinking about putting in a "sentinel" value of -1 (signed) = 255 unsigned.
I don't think the car wouldn't even reach a terminal velocity of 220 MPH if tossed out of a 747...
- Mud guards
- Wheel locks
- Silver AEM CAI
<font face="Verdana, Arial" size="2">Originally posted by CLTypeR:
</font>
</font>
cycdaniel
Dec 17, 2019 10:58 AM
BoricuaTL
Apr 8, 2016 01:08 PM
