Anyone heard of this Sh*#
I had some pro-kit springs installed on my car 2 weeks ago, the front was and is sitting higher than the back, but i have heard that all cars are like this, because the front springs are so much thicker like a 750 rate compared to a 450 rate on the rear. Is this true does it take the front longer to settle. Also there is a popping noise from the left front of my car . I had it inspected and they said that the spring was sitting in there right, that the noise was form the rubber housing at the top of the spring. The guy said it might stop popping in 5,000 miles or less if not i might need a new housing. Anyone ever heard of this??
I have the same problem with the different size gap. I called eibach and they said this is normal. Park your car on a flat surface and see if it sits even. Mine looks perfectly flat.http://www.acura-cl.com/forums/showt...threadid=38292
Re: Anyone heard of this Sh*#
let me say this though if your saying the front gap is larger than the rear but its witht in .25/.50 ...this is normal especially if you have a full tank or system???? if its dramatic thats another thing ...got pics???
Sorry no pics, but I'm not too worried about the difference the front is only a little higher, but what should I do about the popping noise it sounds like it is getting less the more time goes on, but it is still annoying the shit out of me.
Thanks TypeR, no I have never heard of the isolator, someone else said they thought they cut the bumpstop too much, ever heard of that? The pop happens at lower speeds, it seems that more speed and downforce on the car seems to make it stop, in other words if i'm going over like 45mph, i can't hear it. How would I go about adjusting the isolator? Thanks
Originally posted by fbazakos
saw pics like this ... seems normal ... as long as it isnt too exaggerated. put some koni's on ... then you're back end will pop right up and you'll have a nice raked look.
I think the problem is, maybe a loose nut or bolt during installation, you dont need to cut your bumpstops nor do you REALLY need the isolators for the Prokits...I wish you were here, then I can fix it for you, but your too far, Spring installs are easy, btw got my rear tokico shocks with updated upper mounts for my Ground Control Coilovers today, and need to install it with my Gorilla Torque Wrench...interesting day...
MetalGearTypeS
08-29-2016 08:28 PM
