Another Octane Question
Old Feb 13, 2001 | 04:03 PM
eric's Avatar
I was reading the previous posting regarding octane. And there seemed to be differences of opinions regarding whether or not higher octane will make for better performance. Does it? Has anyone compared times? As well, what does octane boost do?
Old Feb 13, 2001 | 04:18 PM
juniorbean's Avatar
Below is a reply from another forum by a poster named Toolman. It's a great reply, hopefully it will help you guys out....
Hey,
I've been reading here for a long time, and haven't registered until now to clear up the
popular misconceptions about high octane fuel. You've listed most of them here: more
power, cleaner, hotter, etc. None of these are true.
Octane is simply a measurement of the fuel's resistance to ignition. The higher the
octane number, the more resistant to detonation the fuel is. That means that your car tends not to knock and ping on higher octane because it won't detonate until lit by the spark. Knocking and pinging is pre-ignition of the fuel charge, caused by hot spots in the cylinder, compression, and other factors like heat and load (and conversely, lower octane fuel does not contain more BTUs than high octane, it's just more vulnerable to pre-ignition).
The reason cars like the TL need high octane is to prevent detonation, not make more
power. What the high octane does is allow the engine to MAKE ALL THE POWER THAT WAS DESIGNED INTO IT. It is rated at 225HP, and that's all it'll ever make (without modifications), even if you put in 130 octane fuel.
You will, however, notice a loss in performance by using lower grades of fuel, but not because of the fuel itself. The TL is equipped with a knock sensor that retards timing when knock is detected, effectively cutting power. With high octane fuel, there is no knocking, therefore, no retarding of the timing and full power. But the fuel itself WILL NOT MAKE MORE POWER. Like one gentleman said, use only as much octane as you need to prevent knocking--any more (like the 100 octane mentioned) is just throwing your money away. You aren't getting more power out of fuel. A set amount of air and fuel, regardless of octane, will only make a certain sized explosion. Whatever you may hope or have heard from people who are not quite sure what octane does, it definitely does not magically make more horsepower from otherwise standard engines. I hope this is helpful..
1998 Iced Blue CL 3.0 ** Some mods, but who cares, I want a Type-S!!
Moderator - 1st Gen Forum
Email: juniorbean@acura-cl.com
Old Feb 13, 2001 | 08:07 PM
WV250R's Avatar
Thank You JUNIORBEAN!! Octane seems to be one of the most missunderstood technical aspects of the internal combustion engine!
Old Feb 13, 2001 | 08:12 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
I disagree somewhat....yes, on lower compression vehicles higher octane won't help. But high compression engines run faster with higher octane gas...of course, anything above 105 is leaded and not for use in our vehicles.
2001 Cl-S Black on Black with Navigation
Weapon-R Dragon Filter
[This message has been edited by moomaster_99 (edited 02-13-2001).]
Old Feb 13, 2001 | 08:19 PM
CLpower's Avatar
teh Senior Instigator
<font face="Verdana, Arial" size="2">Originally posted by moomaster_99:
</font>
thats what i'm saying!!!!
and anything over 109 is leaded
Old Feb 13, 2001 | 08:43 PM
oh...something like that...=T
Old Feb 13, 2001 | 08:44 PM
are you just saying things to post ***** again!?!
Old Feb 13, 2001 | 11:58 PM
Jens H.'s Avatar
retired
Actually it all depends on how your car's fuel injection ecu works.Most cars nowadays use a device known as a "knock sensor".What this thing does is listen for the dreaded knock,both the audible and inaudible kind.Should it detect knock it retards the timing to protect the engine.Since not all forms of knock or ping are detectable by the human ear you may be running cheap gas and the computer is compensating for it by retarding ignition timing.What this does is reduce engine power,so if your car is so equipped (yes your Acuras are so equipped!) you are actually getting more power out of it by running the correct octane.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA headlamp system tinted custom taillites and on and on
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
