another 13.2 run
Originally Posted by bigguyonbike
how high do you plan on going with your CR?
I will have the following:
'03 CL-S block
'03 CL-S head gaskets
'04 Odyssey crankshaft/rods/bearings
'05 RL pistons/rings
and remaining '03 CL-S heads, scalbert's IC.
I'm also going to use Vortech FPR called SFMU w/larger '04 S2K injectors
Originally Posted by 02AV6
as long as my AFR is fine. Bigger injectors, FPR, e-Manage and tuning =
No coating on RL pistons, they look great to me with perfect clearance for CL-S large (intake) valves:
Left to right: '05 RL, '04 Odyssey, '04 MDX
It definately will be strong, the low-end torque and overall powerband for sure comparing to my previous dyno, it just only frigging AV6 ECU is a bottleneck to approach to 400whp and I need to find some ways to crack/replace it. Myself and another guy are currently checking ways to see if 1st gen. 3.2 TL (4AT) ECU will work without entire harness replacement. ThinJim ride will be very strong with built block, turbo and 6MT. However, when getting 350+whp on our rides I prefer auto when tracking and mine prooved to be strong.
SinCityTLX
Oct 7, 2015 01:24 PM
. We currently investigating other solutions.
