annoying things on CL
Old Jan 8, 2013 | 07:14 PM
  #121
Oldsman71's Avatar
Ok I've only had mine since end of August. Haven't noticed an issue being able to see around the piller or mirrors. Drive a pickup most of the time, so maybe I'm used to big pillars and mirrors. Kinda irritated with the radio volume control, but steering wheel control works just fine. I doesnt seem like the mode selector on climate control does very good at moving air from floor to vents to dash (defrost). Probably needs something lubed or adjusted. I dont think the steering wheel contol butons light up very well at night. (I have the same bitch with my wifes '08 TL) Car is a blast to drive and I only drive it on nice days on the weekend or to go golf, so most of these issues are mere annoyances.
Old Jan 9, 2013 | 05:40 PM
  #122
Catfisha's Avatar
Giant Blue Car
The only complaint I have is the turning radius...
I don't use any radio controls on the steering wheel, so if they're jacked up, I won't know about it...
Old Jan 12, 2013 | 08:04 PM
  #123
civicdrivr's Avatar
This x 10000000
Old Jan 13, 2013 | 06:05 AM
  #124
Inspect and/or change the cabin filter.
The only thing, ATM, I'm not liking is the driverside seat belt retractor spring is weak/worn and does not return normally.
Old Jan 13, 2013 | 10:28 AM
  #125
mikebikelife's Avatar
@Mikeshlong On IG
I find the turning radius to be good ? odd . If I can't make the turn I just stomp the ebrake pedal . problem = solved .
Cupholders are a joke .
Old Jan 13, 2013 | 10:29 AM
  #126
TheWeez's Avatar
I Wanna Beer
Might work in snow or you have shit tires.
Old Jan 14, 2013 | 03:33 PM
  #127
civicdrivr's Avatar
Vegas has wiiiiiiiiiiide roads.
Old Jan 15, 2013 | 01:34 PM
  #128
@Mikeshlong On IG
We also have 4 spaghetti bowls within 30 miles ...
I use good tires I just know how to drive . Turn push ebake and gas, make a u turn in 2~3 lanes easy . Worked on my dunlops,nittos,nankang,and accilles.
Old Jan 15, 2013 | 02:14 PM
  #129
TheWeez's Avatar
I Wanna Beer
Uuuuh, even lowered I can make a u-turn in a 3 lane road with no problems. No need to potentially wreck my car and tires by using the e-brake.
Old Jan 16, 2013 | 09:34 AM
  #130
CL-S progression 01's Avatar
lowrd on tein CS biatch
turning radius is definitely not great on the CL but I love the car to death either way. besides I stay away from city driving every chance i get
Old Jan 16, 2013 | 12:16 PM
  #131
@Mikeshlong On IG
You must be a poor driver in that case .
Old Jan 16, 2013 | 12:18 PM
  #132
TheWeez's Avatar
I Wanna Beer
You're saying that using the ebrake to slide your car doesn't scrub the tires a bit and put a side load not intended on the rear suspension? Got it.
Old Jan 17, 2013 | 10:30 AM
  #133
mvitale27's Avatar
Regular maintenance is not an issue for me. However, little things constantly breaking are. Such as all the dash/console/button lights or whatever you want to call them. Currently, my radio, heat/AC, cruise control, mirrors, hazard, and god knows what else (can't know what isn't working as they never have since I bought the car) are not lighting up whatsoever. Only things that do light are instrument cluster (thank god), heated seat, and memory seat currently light up.
Old Jan 17, 2013 | 04:05 PM
  #134
aznboi2424's Avatar
Gotta agree with Weez. There's no reason to use the e-brake other then it's intended purposes on this car.
Old Jan 17, 2013 | 05:05 PM
  #135
brian6speed's Avatar
Lone Wolf
I always assumed that was a design defect since mine did it since it was new. No issues with my racing harness tho.
Center console/cup holders suck on auto. Manual has great cup holders.
I had sight issues from driver side mirror. A small cf mirror fixed that.
Turning radius sucks. Was fine for auto-x tho so dsnt bother me.
Stock brakes suck and no rear bbk available.
Trunk springs are retarded and clunk over bumps. They also rip the metal bracket off. No room in trunk to mount struts.
Our clutch is the only year to have sensor on flywheel.
Auto tranny is defective.
Axles could be stronger and better protected from corrosion.
No aftermarket support
Stock seats do not go low enough. Fat people can't fit through door opening to get in back seat.
This car is prone to rust.
Moonroof dsnt open enough. No option to not get the moonroof.
Rear view mirror is defective and can damage interior.
Not a fan of the damper on clutch or slave check valve.
Dash deforms over time.
Rattles from dash and third brake light(not big deal)
Ends of wipers don't contact windshield.
Wheel hop issues.
That is all I can think of now off the top of my head.
Old Jan 17, 2013 | 05:52 PM
  #136
lol, it may be. Its retraction ability slowed about 24 months into ownership for me and, even though it is annoying, it has not progressively become worse ever since.
I have brought it to the attention of a few service advisors over the years to try and get it replaced via the life time warranty on the restraint system. Basically, they tell me that it still retracts, and until it literally siezes up, no replacement.
I just purchased a new one and I will be doing the replacement myself with the help of the Helms manual, so we'll see.
Old Jan 17, 2013 | 06:02 PM
  #137
Lone Wolf
Ahh the retracting mechanism on mine has always worked. I was thinking more of how it gets caught on the seat and in the door jam.
Old Jan 18, 2013 | 01:04 AM
  #138
@Mikeshlong On IG
Than why mod the car for performance , It's a luxury coupe . Grab the ebrake and have some fun . Slide the tires and make a scene . Otherwise get into a prius .
Old Jan 29, 2013 | 03:51 PM
  #139
aznboi2424's Avatar
I never modded this car for performance
The steering wheel controls don't light up at all.
Fabian43
Jul 13, 2016 09:07 PM
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
Feb 26, 2016 03:44 PM
Frathora
Sep 28, 2015 11:29 PM
