Amsoil 0w-20...? 03-CL 6speed
Im wondering if I should use 5w-20 instead of the 0w-20 I already bought; either way I'm using Amsoil.
I only care about getting my car to preform the max potential. Im not as concerned with millage between changes. I bought the oil from a distributor who ran the specs on my car and recommended the 0w over the 5w but I know he makes a few more $ on the 0w. I live in Missouri so it does get kind of cold and I drive my car hard. Down sides? Up sides? What do you guys think? Who runs Amsoil in their MT's and what do you use?
I also bought the engine cleaner which they told me to use prior to the change to clean out the gunk. I was instructed to poor it into the crankcase and let the car idle for 15mins, shut it off and proceed with the oil change. Any advice regarding that?
Hook it up guys! And happy Thanksgiving!!
EzE
EzE
The only difference is on cold start up. If it gets really cold definitely use the 0w-20. The engine cleaner sounds like a good idea. I would run a little clean oil through after the old oil is drained out.
When you say "run" clean oil through after the cleaner, what exactly do you mean? Are you saying use cleaner, drain all oil, refill with clean oil and run it through for a few mins, then drain again and then refill again for completion?
Yeah, I do that as well. I picked up the 0w-20 based on what I was told by the Amsoil guy who based his recommendation off specs (specific to the j32a2) from the Amsoil website. Can you think of any reason why 5w is "better" than 0w?
thanks fuzzy
thanks fuzzy
I agree with your "pretty safe" comment as well. ...we'll see...
Thanks Chuck
No oil viscosity provides enough protection at cold start up but they all do a really good job of "thinning" out to about 10cs, cold start is critical so just go with 0-20, its usually more expensive. As of now im going 5-20
It does get fairly cold here but not for the duration of time (25k miles) Amsoil allows between oil changes. Having said that I am truly interested to know if when it gets hot 0w will have a negative effect on anything.
STL TL-S
09-23-2015 08:52 PM
