? For all manual/stick drivers
CL-S 6spd
I seem to not be doing something right maybe you guys can help. Here is my problem. I have a CL-S and had an integra before and i had the same problem. It seems that my clutch pedal looses pressure at times and it changes the engagement point where the gear catches. Because of this it causes me to almost stall "sometimes" if i do not recognize it. I checked my fluids and they are good. I will be flushing out fluids soon to see if that helps again i had the same issue w/ my teg. I changed fluids in the teg and still had same problem. Am I doing something wrong possibly? The gears do not grind or slip however it seems like the threshold for engagement point seems to be getting shorter and leading me to believe clutch will go sooner rather than later. Please help!!!!
It could be the master cylinder, but at that many miles it could also be the clutch and there's a higher probability that it is the clutch and not the master cylinder.
It all depends on how you drive your car and how well you shift, but most people average between 80-100K on their clutches, some much less.
I think on my GS-R I went about 80K and had to get the clutch changed on it but I also drove that car very hard because it was so much fun to drive.
My CL-S on the other hand I got 150K miles on the first clutch before it needed replacing.
One thing to note:
If you do in the end need to get your clutch replaced and IF your flywheel needs replacing as well, opt to have them install the OEM Type-R flywheel instead.
I did that on my car and it made a world of difference in shifting and the price difference between my GS-R flywheel and Type-R flywheel wasn't much (at that time)
CL-S 6spd
I have a CL-S..no longer have the teg.....Well i will bleed fluids today and see what happenes from there....do you know where the drain and fill plugs are the the tranny on the CL-S? Thanks for your help dude!!
One thing to suggest, for about $25 and some labor, you could swap your standard clutch line for a stainless steel line for improved clutch response.
quite a few guys have done it lately and have reported good results from it. Do a search for it and you'll see.
if you do that search you will also find info about how to bleed the clutch system from when people installed the stainless steel line.
CL-S 6spd
I will do once i get home...i'm @ work now..trying to keep internet usage to a minimum....do you know where i can purchase one @ a retail store so i can do this today?....
Here's some quick links I found for you
https://acurazine.com/forums/showthread.php?t=184271
https://acurazine.com/forums/car-parts-sale-361/aem-cai-sale-2002-type-s-190735/
Part Info:
http://www.techna-fit.com/clutch.html
The part # is HNC-011, the part is listed for an accord, but others say it works for our CL
xsilverhawkx
09-28-2015 06:51 PM
