Alarm Issue
Old Jan 11, 2010 | 07:01 PM
madmuzik09's Avatar
Waits for Shakira in his
Alarm Issue
Ok so my battery died a few days ago and today i just noticed the alarm doesnt go off if as it usually would. But te keyless entry still works, so basicly how do i reset or fix this issue. I am now very parinoid
Old Jan 11, 2010 | 08:01 PM
friesm2000's Avatar
B A N N E D
oem or aftermarket???, cause oem should not have changed with a disconnected battery, an aftermarket one kinda depends on the alarm itself
Old Jan 11, 2010 | 09:48 PM
madmuzik09's Avatar
its the oem, how can i test it out because my friend was shaking the car and then i open my window locked the car and opened the door manually and nothing happened
Old Jan 11, 2010 | 09:57 PM
victorvu's Avatar
press the panic button if it sirens then its still working also if you lock your car the driver door lights up a little red led light next to the lock.
Old Jan 11, 2010 | 09:58 PM
friesm2000's Avatar
B A N N E D
shaking- no shock sensor, so it will not go off for that
unlocking it from inside- did you give it a full 30 seconds or so, to fully arm itself or just opened it right away; the light flashing pattern should change (pretty sure) on that security light right next to the lock knob on the driver's door
Old Jan 11, 2010 | 10:05 PM
madmuzik09's Avatar
oooooo oops lol i didnt give it any time and yea the light still flashed and i will hit the panic button in the morn its too late for all that noise. But thats for claring this up for me... sound like I need a viper alarm/ starter
Old Jan 11, 2010 | 10:57 PM
madmuzik09's Avatar
since were on the topic of programming , sort of, how do you program the remote move the seat to memory one when you hit the unlock button
Old Jan 11, 2010 | 10:59 PM
friesm2000's Avatar
B A N N E D
first of all, what does the remote say on the back 1 or 2 or nothing
also is the seat position memorized already
Old Jan 11, 2010 | 11:02 PM
madmuzik09's Avatar
yea the seat is already programmed and it says 1
Old Jan 11, 2010 | 11:12 PM
friesm2000's Avatar
B A N N E D
try moving the seat to a different positon (do not reprogram the memory), then lock and unlock it, then when you open the door you should here the seat moving, and when it gets to the memorized position it should beep like 3 times inside the car to tell you it is there
if non of that happens, it sounds like the remote has been unlink from memory position, so push the lock and unlock buttons at the same time (prefueably near the car just to make sure) and hold them both down for i think like 10 seconds, and you should get a comfermation tone from somewhere that the memoray system is relinked with the #1 remote
then repeat above to doable check that fixed it
also remote #2 is exactly the same as above, just with the 1's replaced with 2's
Old Jan 11, 2010 | 11:23 PM
madmuzik09's Avatar
thanks alot, this is why i love this site
Old Jan 11, 2010 | 11:24 PM
friesm2000's Avatar
B A N N E D
worked then???
Old Jan 11, 2010 | 11:39 PM
madmuzik09's Avatar
yea man thanks a lot, all issues solve tonight
Old Jan 11, 2010 | 11:44 PM
friesm2000's Avatar
B A N N E D
Sweet...... and NP
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
njresendez
Sep 21, 2015 11:23 AM
carz0159
Sep 20, 2015 06:11 PM
