after sway install problems.
A-CL nub
got my sways, pulleys on yesterday. couldn't really tell a diff. with the pulleys, the sways are great though and i could immediately tell.
here's the problem. instead of going by the instruction manual, where they say to take the wheels off when installing the front to get the bar off, he unbolted my headers and lowered it to get it off. i didn't have a problem with this, but when i started my car and revved a little...the sound was totally different. doesn't sound like a v6, but more like a 4 banger if you guys know what i'm talking about. i was thinking there's a leak somewhere, but i saw him bolt everything back on, and it seemed alright. he was kinda rough with it getting it off, maybe he cracked something up top? i don't know what it could be. also, i couldn't really tell a diff in acceleration after this noise. any clues? thanks.
rich
rich
Back to Four Doors
Re: after sway install problems.
rich
rich
It does sound like something got misaligned somewhere. How are the connections to the rest of the exhaust system?
A-CL nub
well i was under the car on the lift when he was putting it back together, and i checked the bolts from the front/rear headers as well as the rest of the exhaust...it all seemed fine to me. :\
Why remove the headers at all???? That is not needed.You just unbolt the mounts on the subframe and the joints on the lower control arms and slide it out to the side .
Jens
Jens
nearsighted visionary
I was able to install CT anti-sway bar without removing wheels or headers. I'd wager the exhaust manifold gasket is not sealing. Show up with new gasket when looking for leak, you can take it back if not needed. Good luck.
A-CL nub
ok. i found the gaskets, not too bad of a price. just wondering. you know how you have to retighten the headers after a month or so...say they were loose a little. the sound could change right? i wish i could get a sound clip of what it sounds like.
marcelft
07-10-2018 06:17 PM
MonkeyTrucker
09-21-2015 06:15 PM
k6biv
09-10-2015 06:37 PM
