Affordable Camber kits for you... (front and rear)
http://www.obxracingsports.com/perfo...=4&subCat2ID=3
And this for for 99-02 3.2TL ( should be the same as the CL, right?)
Originally posted by moomaster_99
Hmmmm....OBX quality for my suspension too!?!?!?
If you get bad headers, you send them back and waste some time and money. (You could still end up saving money). If you put a "funky" suspension part on and it breaks on a mountain road or the freeway, you got to think about that.
I'm serious...
Don't ever “cheap out” on brakes or suspension parts (that includes tires and wheels too)!
Originally posted by 2001CL
sorry i dont exactly what camber kits do, could you please explain.
If you lower the car enough, the camber of the tire/wheel changes and causes excessive wear on the inside of the tires (front and rear).
An additional degree of negative camber (what you get when you lower the CLS below a set drop) will give you some increased "stick" in turns, but CAN also cause the inside of the tires to wear out too soon. The wear depends on percent of freeway to twisty driving and other factors (like how much the car is dropped).
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
