View Poll Results: Which is better?
AEM v2
33.33%
Comptech Icebox
66.67%
Voters: 15. You may not vote on this poll
AEM v2 vs Comptech Icebox
Im in the market for a new intake, since my aem cai is gettin worn, I need to replace it, flat out which provides more gains, and whats the pricing on the two?
teh Senior Instigator
aem v2 is out
but what do you mean your AEM is getting worn? YOu realize the filter will last you for life? You are suppose to be cleaning it.
If it's torn up to bad, you can just buy a new filter for like 30$
it would be absolutely pointless to go get a new one, you won't get anymore gain out of them.
Originally posted by Aegean_Blue6
That worries me a bit too. I figured that with occasional filter cleanings I'd be good for life with the AEM. How is yours worn out?
what worries you? btw, you should clean it every 4-6K
Just if there's any failures, I'd like to know about it - Seems like if the pipes cracked or something, lots of not-so-good-stuff could be sucked into the engine. I've heard about failures with the bypass valve, but none with the intake itself yet.
The intake has only been on the car for about 5k, so I'm just now starting to think about cleaning it. I've heard everything from yoru 4-6k miles, to once/yr to 25-30k miles, but I'll probably check it every 5k and clean it when it's dirty., but at least once/yr
Originally posted by CLpower
aem v2 is out
aem v2 is out
I have a v2 but i had to modify it from an accord just had to cut about 4 inchs and bend the mounting bracket a little. i think i felt a little slower of the line then the short ram i had maybe just my imagination because it not as loud
Originally posted by kHmER Co
the pipe has a hole from rubbin against the side.. i cut it for the bypass valve. its just.. lookin shitty. ;]
huh?
Originally posted by Python2121
How do you clean the aem?
my brothers is overdue for a cleaning
go to any auto store and find the K&N filters. They have a thing called a recharging kit, it's about 10$. The cleaning instructions are inside
