Aem Cai? Diy?
Old Feb 21, 2010 | 10:57 PM
  #41
civicdrivr's Avatar
Piccy no worky.
Old Feb 21, 2010 | 11:05 PM
  #42
CL-S progression 01's Avatar
lowrd on tein CS biatch
see i just took off the bumper.. took me 4 mins. and made everything else so damn easy.
Honestly I think it's no slower to remove the bumper. as long as u can put it back on properly LOL
Old Feb 21, 2010 | 11:06 PM
  #43
Elijah J's Avatar
Originally Posted by NiteQwill
Don't forget to bleed your coolant line for air.
I believe this i corporate. I dint bleed it and Im god damn sure the biatch is hooked up right. I lost coolant in the process and had planned to hit up an auto parts store once finished. But im not driving it until it gets back to normal.
Old Feb 21, 2010 | 11:12 PM
  #44
Elijah J's Avatar
Did you relocate the coolant line under the throttle body as illustrated in steps "g" an "h" from http://www.aemintakes.com/instructio...1-509_inst.pdf ?
Old Feb 21, 2010 | 11:19 PM
  #45
Elijah J's Avatar
Piccy no worky.
yeah, todays not my day. The pic was of steps "g" and "h" from this http://img524.imageshack.us/i/hpim2811xh5.jpg/
Old Feb 22, 2010 | 06:35 AM
  #46
Elijah J's Avatar
Alright, i looked over chod's write up and I dont see wtf the problem is. Why is the idle so jacked?
Old Feb 22, 2010 | 07:21 AM
  #47
Elijah J's Avatar
Air pocket. ... Fixed.
Old Feb 22, 2010 | 07:56 AM
  #48
forgot to bleed the system ?? lol it happens
Old Feb 22, 2010 | 03:24 PM
  #49
Elijah J's Avatar
All's good except for the idle. It fluctuates between 1500 and 2100 depending on the incline im parked on...Why?
Old Feb 22, 2010 | 03:45 PM
  #50
yes I did step g and h... with the double male adapter they give u in the kit...
as for the idle fluctuation...you either got a vaccume leak or have overlooked something you did in the modding process.
also, unplug ur 7.5 amp fuse by the passenger firewall for 15 sec and see if that changes anything
Old Feb 22, 2010 | 04:00 PM
  #51
Elijah J's Avatar
Thanks for being on top of this thread. You must not get much work done. lol just kidding...I bought this used and recieved only the intake pipe, filter, breather hose and 3 hose clamps, and the soft mount. I know not of this double male adapter you speak of. Pic?
I assume youre reffering to the ECU?
Old Feb 22, 2010 | 04:46 PM
  #52
noo.. I mean when connect those lines together you need a piece/fitting which is double male so u can connect both hoses together when going under the intake.
Cause u remove the old metal hose right?? so u need to compensate for that length by going underneath everything and using that piece.
How did you accomplish the install without that piece? did u just use one long hose?
Old Feb 22, 2010 | 05:43 PM
  #53
civicdrivr's Avatar
If you can take a picture of what you did so far.
Old Feb 22, 2010 | 09:30 PM
  #54
Elijah J's Avatar
I dont have a camera. I have done pretty much exactly what is laid out by AEM (http://www.aemintakes.com/instructio...1-509_inst.pdf).
Removed metal breather/coolant line. Replaced breather with the 5/8" hose. Did the coolant-line maneuver from steps G and H. It says in step H to rotate and reconnect the coolant line. I wasnt able to rotate it much but I did reconnect by wrapping it around the front. And then I reconnected the other line to the nipple farthest from the manifold, towards left, front wheel. Im pretty sure its right, but I had to reuse hoes clamps which left it not as tight as I'd like.
Drove it all day. Liked it. Only thing is its idling at 1500-2000. Wednesday, Ill have time to look at it. I'll probably just buy new hoses and clamps to configure it better. I'll also need to add a small amount of coolant.
This is the only tool I used:
http://http://sogknives.com/store/S44.html
Cutting the resonator off with a small blade was a bitch.
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
lanechanger
Oct 13, 2015 10:56 AM
kingbharj
Sep 25, 2015 07:25 PM
