Aem Cai? Diy?
Old Aug 31, 2004 | 03:44 AM
Time For Sleeep's Avatar
That's Racist
Aem Cai? Diy?
From a 1-10, how easy of an install is an AEM CAI if you do it yourself?
-Could I save time and avoid risking the welfare of my car by paying $40/hr for a shop down here in Diego?
-And what's the best deal out there for the AEM?
Old Aug 31, 2004 | 04:16 AM
bigguyonbike's Avatar
13.2 @ 104.76mph
if 1(easy) and 10(hard), then it's probably a 2 or 3. follow the instruction that is given with the product and you should be fine. take the front driver side wheel and the splash guard off and you should have access to all the nuts and bolts that need to be remove. from there it's a piece of cake. i got my AEM CAI here: http://www.first-1.com/Merchant2/mer...roduct_Count=2
price is $165.95 with free shipping.
Old Aug 31, 2004 | 05:52 AM
Chief F1 Fan's Avatar
put it on yerself and begin the bond w/ yer whip! I'd say it's a 1-2, especially if you are mechanically inclined and you should be done in about an hour.
Old Aug 31, 2004 | 08:05 AM
MisterMehoff's Avatar
If He Dies...He Dies
I give it a 2. It took me 30 mins to install my AEM. I had an Icebox on initially so I pretty much knew what went where.
Old Aug 31, 2004 | 08:13 AM
phipark's Avatar
Not Asian
This was the first thing that I have ever put on a car and I would rate it at about a 3 for a beginner.
Old Aug 31, 2004 | 08:26 AM
I wonder how Amir would rate it???
Old Aug 31, 2004 | 10:27 AM
racersky's Avatar
it's pretty easy once you remove that bottom box which i think is called either the airbox or snorkel w/e. The bolts are on there like there's no tomorrow
Old Aug 31, 2004 | 10:30 AM
You'll probably need a wrench extension attachment to get the bolts off the resonator box. It comes in handy.
Old Aug 31, 2004 | 10:59 AM
Shawn S's Avatar
The BEST way to get the rear resonator bolt off is to access it through the wheel well.
Old Aug 31, 2004 | 11:38 AM
juniorbean's Avatar
This was the first mod I ever did myself and it took me about an hour and a half total. On a scale of 1-10, 10 being the hardest I'd give it a 3.
Good luck!!
Old Aug 31, 2004 | 01:21 PM
evilone's Avatar
COME AT ME BRO!
its easy just get a jack stand and take your front left tire off so you can get in the wheel well liner easy.. i would give it a 2.. tools needed jack stand, flat head, phillips head,jack, impact wrench or factory lug wrench, and i think thats it you might need a 10mm socket some where i dont remember its been like 2 years scene i put mine on.
Old Aug 31, 2004 | 06:57 PM
racersky's Avatar
lol i know i did that but there's that on bolt that's facing the front i think inside all the way up.
Old Aug 31, 2004 | 09:25 PM
That's Racist
Thanks everyone. Looks like I'll save $40/hr.
Old Aug 31, 2004 | 11:11 PM
NiteQwill's Avatar
Adventurist.
Don't forget to bleed your coolant line for air.
Old Feb 20, 2010 | 12:16 PM
Elijah J's Avatar
I know this is old...but what?
Old Feb 20, 2010 | 12:28 PM
civicdrivr's Avatar
I think he was talking about the coolant line in the throttle body, but Im not sure why anyone would undo those when installing a CAI.
Old Feb 20, 2010 | 12:43 PM
Elijah J's Avatar
that was I was thinking and wondering. I just bought a used cai for my CL MT and didnt get an installation manual. Im sure its pretty simple but it would be nice to have something check myself against, anyone have a DIY or a link to instructions?
Old Feb 20, 2010 | 12:52 PM
civicdrivr's Avatar
Its quite simple. Just remove the stock air box and tube along with the resonator (best to do it from the wheel well).
Then put the new intake in. Its difficult to screw it up.
Old Feb 20, 2010 | 12:56 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
it took me just under 1 hour. it was my first mod, I had NO instructions... and I removed my front bumper (which you do not need to do)
Old Feb 20, 2010 | 02:22 PM
Rapture's Avatar
I think with an Injen CAI you need to mess around with the coolant lines.
Old Feb 20, 2010 | 03:40 PM
civicdrivr's Avatar
You shouldnt have to. There is a vent line from the front valve cover that you need to connect to the intake pipe, but no coolant lines.
Old Feb 20, 2010 | 04:38 PM
no coolant lines to redirect. it's a straight forward install. You get instructions to show you what to do on Injean and AEM(i think), and in my kit u get a hose to go from the intake to the front valve cover and then u remove the oem metal pipe and then attach a double male fitting to another line (forgot what it's called, but it goes to the other side of the intake). It's nothing really, just read and do slowly
But if u got the tb spacer and gaskets there bushing becomes too wide and there is no clearance so u need to do something. I cut my bushing in half and then fabricated a lil bracket to hold it in the same place by an inch closer to the frame.
Old Feb 20, 2010 | 06:21 PM
Elijah J's Avatar
Right on dude. Thanks for the input. Being that I pick this puppy up used from a fellow Azine member, no written instructions were available. However, AEMintake.com does have a how-to posted. It looks like a nobrainer, I'm just looking for shortcuts. For example, you mentioned not needing to remove the front bumper.
Anyway, thanks dude. Ill knock it out tomorrow. The current is busted as shit and hums something fierce.
Any luck with the ebay filter?
Old Feb 20, 2010 | 08:02 PM
no i just went and got an Injen one and said to hell with it.
Costs a lot of money but I'm sure it's better a little bit. to what degree who knows but I am a brand loyal custy and i stick to ma gunz
Old Feb 21, 2010 | 11:20 AM
Elijah J's Avatar
This is the instal sheet from AEMintake.com. For the MT CLs, its calling for the coolant line to be relocated. Did you guys not do this?
Coolant line: http://www.aemintakes.com/instructio...1-509_inst.pdf
Old Feb 21, 2010 | 11:34 AM
civicdrivr's Avatar
wtf?
I have an Icebox and didn't touch any coolant lines. What the point to in H isn't a coolant line, thats the breather hose.
Old Feb 21, 2010 | 12:04 PM
Elijah J's Avatar
wtf?
Hmm.
Old Feb 21, 2010 | 12:57 PM
Rapture's Avatar
Hmm indeed.
Old Feb 21, 2010 | 01:31 PM
victorvu's Avatar
i think they're talking about coolant bypass when doing cai its recommended to do the bypass from keeping warm coolant from heating up your throttle body. If anyone in here has a CAI they probably have the bypass also.
Old Feb 21, 2010 | 04:08 PM
2Fast4you's Avatar
doing the bypass makes my car warm up really slow in the winters and i get shit mileage because of that.
Old Feb 21, 2010 | 06:00 PM
civicdrivr's Avatar
The bypass shouldnt have a damn thing to do with the engine warming up.
Old Feb 21, 2010 | 06:47 PM
bypass only screws with the idle (sometimes) I did this mod on my previous car and on cold days it'd act wonky.
Not saying it'll do that same, but it's just not my cup of tea.
The tb is designed to have the coolant go through it. I'm not a fan of tampering with that. Especially because we often have cold days in canada.
Old Feb 21, 2010 | 06:51 PM
civicdrivr's Avatar
In cold climates I wouldnt suggest it. Ice can form in the throttle body then its not really fun for anyone involved.
Old Feb 21, 2010 | 06:53 PM
lol i didn't even think/know about that. that just ironically just reiterates my point for all of the
Old Feb 21, 2010 | 07:44 PM
Elijah J's Avatar
There are two nipples on the intake. 1 is for the breather hose, what about the other?
Old Feb 21, 2010 | 07:46 PM
Elijah J's Avatar
of those who've posted, who has put the aem cia on a six speed?
Old Feb 21, 2010 | 07:50 PM
there is only one there that size that can go on it anyways so it's like... impossible to screw it up
Old Feb 21, 2010 | 07:57 PM
Elijah J's Avatar
For the record, dont attempt this is all you have is a theatherman...real pain in fucking ass without proper tools(damn the bitch who stole my sockets).
Somethings not quite right. I followed the directions from http://www.aemintakes.com/instructio...1-509_inst.pdf .
But when I give it gas it goes to 4k rpms and stays. I need to fix this tonight. Who else has installed this with similar issues?
Old Feb 21, 2010 | 09:49 PM
darkness_cl's Avatar
not hard at all definately do-able by yourself without the help of a body shop. The hardest part is just looking for the 2nd bolt behind the resonator >.<
Elijah J's Avatar
Is this process considered a coolant bypass?
